Author Topic: 555 question  (Read 1342 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
555 question
« on: August 08, 2017, 11:48:49 am »
Hi everyone,
I don't understand the use of the third 555  on the right.
I joined a LTSpice simulation.  You will have to press escape after 3 seconds to see the raw result.  (don't know why)
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline ironmonkey
  • Country: co
Re: 555 question
« Reply #1 on: August 08, 2017, 01:54:31 pm »
The first 555 oscilate to a low frecuency, shoots the timer that limitate the time the fence is electrified (thats the pin 4 all about) and finally the last 555 oscilates to a higher frecuency to control the flyback
Re: 555 question
« Reply #2 on: August 08, 2017, 03:16:56 pm »
 ;D  The flyback?  The newbe  don't understand.
Offline ironmonkey
  • Country: co
Re: 555 question
« Reply #3 on: August 08, 2017, 04:57:01 pm »
Flyback is the name of the circuit at the right (transistor and transformer) which elevates the voltage.
The first 555 marks the intervals between high voltage pulses, the second marks how long that bursts last and the third one drives the high voltage circuit.
If you had only the third 555 (with pin 4 connected to v+ of course) you'll get a continous high voltage output at the secondary of the transformer.
The following users thanked this post: J4e8a16n
Re: 555 question
« Reply #4 on: August 08, 2017, 06:53:08 pm »
" the second marks how long "  it's square wave putting the reset to ground?
Offline ironmonkey
  • Country: co
Re: 555 question
« Reply #5 on: August 09, 2017, 03:54:27 am »
More like how much time can put the reset at high (the time we can set at the second 555), thus, running the high voltage pulse train
Enviado desde mi MotoG3 mediante Tapatalk
