Voltage 0.093v when range is set to 60K and resistance is 935 ohms
Voltage is 0.82v when measuring in 6K and resistance is 820 Ohms
You were trying to measure in-circuit. When doing so, it is almost always needed to keep the test voltage below 0.5V, and better to keep it below 0.2V, as many types of semiconductors will start to conduct above those voltages.
You went way above 0.2V in the last measurement. So it is likely that you saw some semiconductors with your measurement, and also likely that the meter is technically OK. It is just that that specific range is not fit for this particular use case.
The meter uses a rather high current at that range, which is bad for in-circuit testing, but good for out of circuit milli-ohm testing. You must be aware of the specifications of your tools and adapt the settings for how and what you test.
As explained above, some meters have a "low power" mode for resistance measurement, which might help you for in-circuit testing.
I looks however that the SDM 3045 does not have such a mode (the SDM 3055 doesn't, just extrapolating here). But even if you have that "low power" mode, in-circuit testing is very tricky, as coils and caps can easily influence the results as well. Just imagine a low test current, and you are testing over a big cap. That will suck up all the current, and again you will end up with a value that is too low. Not the meter's fault, just a side effect of how you measure.
