Author Topic: Anyone knows this device?  (Read 3571 times)
Offline AlphZeta
    • Kerry D. Wong
« on: February 13, 2012, 12:41:07 am »
Hi guys,
I have quite of few of this three-terminal devices (removed from satellite LNBF). Unfortunately I couldn't find the datasheet for it. If you take a look at the photo below, you will see that the device has the marking of SB2940G.
The table below lists the voltage drops among the pins when measured using the DMM diode range: (The device pins are 1, 2, 3 from left to right. The column represents the + lead and the row represents the - lead. So for instance, the voltage reading is 1.59 when the negative lead is connected to the middle pin and the positive lead is connected to the first pin). The voltage drop readings seem to be from two diodes connected in series but it doesn't look like a darlington though.
Any advice is greatly appreciated!
-+123
1-inf.inf.
21.59-1.59
31.79inf.inf.
Offline klafaille
Re: Anyone knows this device?
« Reply #1 on: February 13, 2012, 01:30:40 am »
The G suffix doesn't appear in it, but it's likely a flavor of voltage regulator as seen in the attached datasheet.
« Last Edit: February 13, 2012, 01:33:50 am by klafaille »
Offline amyk
« Reply #2 on: February 13, 2012, 10:26:05 am »
I agree with this. It's a Sino-Matrix SB2940 8.5V 350mA LDO: http://www.sinomatrix.com/eng/products.html
The part number resemblance to the LM2940 is probably not coincidence.
Offline AlphZeta
    • Kerry D. Wong
« Reply #3 on: February 13, 2012, 02:22:02 pm »
Thanks guys! I googled "SB2940" as well but nothing meaningful came back (SB2940 returns a bunch of non-related legislation stuff).  I will give it a shot.
Offline DaveHardy
« Reply #4 on: February 18, 2012, 02:03:30 am »
Not a lot of beginners know this, but Japanese bipolar transistors are prefixed with a: 2SA, 2SB, 2SC or 2SD, and FET-s with 3S:
2SA - PNP, HF transistors,
2SB - PNP, LF transistors,
2SC - NPN, HF transistors,
2SD - NPN, HF transistors.
It doesn't work in this situation because the part has already been identified by a previous poster, but sometimes you can try 2SB2940 if you are looking for a cross.
« Last Edit: February 18, 2012, 02:11:34 am by DaveHardy »
