Why not just use the output from the J4 MONITOR socket? No buffer required.
You're within the output stage negative feedback loop there.
What does the output look like?
E
Does anyone recognize this shape distortion? What could be causing this?Try reducing the input level a little bit and see if the observed waveform changes dramatically.
You're within the output stage negative feedback loop there.Exactly, and this means that X3 collector voltage will be whatever happens to be required to drive X4 in such way to produce whatever current that's required in T1 to get the desired output from the final power NPNs. The waveform is distorted to counter an opposite distortion in the rest of the amplifier. I'm not sure why the distortion changed with X3 swap because it really shouldn't change much, maybe you changed or repaired something else too?
It is not expecting 8 Ohm. There is a 82 Ohm series resistor. You csn reduce the level with a couple of resistors.Why not just use the output from the J4 MONITOR socket? No buffer required.
Because it's at speaker level and expecting 8 Ohm? You would know better than me, but that was my reasoning.
If I can just plug the MONITOR OUT from the tape deck into my mixer, with good results, then I don't need buffers at all!
You could simply use a voltage divider to reduce the final output back to line level.
Picking up audio signal from X3 collector is completely nuts. If anything, you could have more luck with the emitter, but note that any nonlinear loading added there may cause distortion in the speaker output and excessive capacitive loading may imperil stability.I was going on @wasedadoc's suggestion here (https://www.eevblog.com/forum/beginners/opamp-single-supply-line-level-audio-buffer-(voltage-follower)-design-help/msg5577821/#msg5577821) <throws wase under the bus> I built a little emitter-follower buffer so as not to load the circuit.
If you want a line output, why you do not take the signal from the volume potentiometer (upper side)? This way, the line out is independent from the volume of the speaker.
If you dont want to load this point, or if the level is not correct for your use, use a operational amplifier.
So then, where in this circuit IS the best place to tap the highest quality signal, to be input at line level into a mixer?Before the whole power amplifier.
If you don't care about volume control, you can save yourself one AC coupling by tapping X2 collector, before C8. This is the signal that goes to the volume pot, but centered around 4.6V.
If you don't care about tone control either, take it straight from the AUX jack ;)
X2 collector - NE5532 at unity gain - 100Ω - coupling capacitor - output jackCode: [Select]X2 collector - NE5532 at unity gain - 100Ω - coupling capacitor - output jack
