Current depends on circuit requirements. Of course. Minimum current is set by required gain, load impedance, bandwidth, noise factor and so on. Maximum current is set by overall power consumption or dissipation limits, input impedance, and bandwidth again to a certain degree.
Generally, with increasing current: noise falls, impedance falls, gain rises, bandwidth rises, and power rises.
As you approach the current rating of a given device, bandwidth falls, due to a combination of the low impedances being more significant against device parasitics (spreading resistance, lead inductance), and high level injection (fT and hFE fall as you approach Ic(max)).
So at some point you choose a larger device, which unfortunately has more capacitance, may have lower fT, etc., but if those aren't the limiting factor, and you aren't subject to other restrictions (like power consumption), that's what you do.
This also applies to MOSFETs, except for injection of course as they are majority carrier devices, and except for input impedance which is more or less independent of current (i.e., mostly gate capacitance + spreading resistance).
