Author Topic: Voltage Drop for an op-amp circuit  (Read 970 times)
Offline DellyjoeTopic starter
« on: November 29, 2020, 04:49:16 pm »
Hello everyone,
I'm working on a home project during these COVID times.
The project is a Distortion effects peddle for a bass guitar.
Here is the output circuit, when I have an 8ohm speaker connected to it.
Does anyone know why the voltage drops? Does it have to do with the output impedance drops to 8ohms when I connect the speaker?
Joe
Re: Voltage Drop for an op-amp circuit
« Reply #1 on: November 29, 2020, 04:49:49 pm »
This shows the circuit without an load on it
Joe
« Reply #2 on: November 29, 2020, 04:51:43 pm »
Here is the circuit in full.
Sorry for all the posts wasn't sure how to attach more then one attachment at a time.
Thank you for reading,
Joe
Joe
Offline schmitt trigger
  • Country: mx
« Reply #3 on: November 29, 2020, 05:00:15 pm »
The amount of bias current in the output buffer is at least 4 orders of magnitude too small to drive an 8 ohm load.
That, and the 2N3904 cannot handle the load even with proper bias.
The following users thanked this post: Dellyjoe, Paul Rose
Offline Paul Rose
« Reply #4 on: November 29, 2020, 05:04:34 pm »
That final emitter follower isn't enough to drive an 8 ohm load accurately.
(plus it will put DC across your speaker without either a blocking cap or transformer).
You really want a full power amp stage if you want to drive a speaker.
You could just use amplified computer speakers, or use something like an LM386 or TDA7267 for a low power small speaker amp.
« Reply #5 on: November 29, 2020, 05:15:48 pm »
Hmm ok that makes sense,
Lucky I have a LM386 that I randomly bought two weeks ago.
I will look into how to run this as a buffer and hope it will give me the power I need to drive the speaker.
Now if I can do that I'm going to plug it into a head my dad has down stairs and see if that works b/c atm it doesn't and I think it has to do with the output buffer not being able to handle the load.
Thanks for the help both of you.
Joe
Joe
