Author Topic: Humming in speakers  (Read 1077 times)
Offline fixit7Topic starter
Humming in speakers
« on: May 10, 2019, 11:31:03 pm »
A humming started in my speakers.
I use a Logitech external speaker system.
If I turn it's volume down, the humming volume goes down.
If I unplug/plug its power source the humming goes away for a while.
Offline Brumby
Re: Humming in speakers
« Reply #1 on: May 11, 2019, 12:25:52 am »
What happens if you unplug/plug the signal input jack?
« Reply #2 on: May 11, 2019, 11:15:08 am »
I found out that the speaker output plug was not all the way plugged in.
Offline Brumby
« Reply #3 on: May 11, 2019, 01:07:50 pm »
Do you mean the connection between your computer and the speakers?
Online radiolistener
  • Country: ua
« Reply #4 on: May 11, 2019, 01:11:52 pm »
Probably you're need to replace electrolyte capacitors in your speakers. This is the most weak elements and often this is a root of cause of malfunction due to low quality.
Offline Brumby
« Reply #5 on: May 11, 2019, 01:19:02 pm »
I went for the low tech idea that a plug wasn't inserted properly.  Looks like I was right - and if the "speaker output" the op mentions is the socket on the computer they're using, then I was exactly right.
An improperly fitted plug is the easiest way to get hum in your audio.
Re-capping the amp in the speakers is not a bad idea - but it would appear to be rather unnecessary in this case.
« Reply #6 on: May 12, 2019, 10:10:19 pm »
Yes.
When I pulled it out halfway, the hum came back.
Offline Brumby
« Reply #7 on: May 13, 2019, 12:30:00 am »
Exactly what I thought - and super easy to fix!
Sometimes you can get the same problem even when the plug is fully inserted - especially if it has been plugged in for a long time.  Contamination build up and/or oxidation/corrosion (which may not even be visible) can interfere with the connections.  Just unplug/replug (maybe a few times) to wipe the contacts clean enough for another period of hum free sound.
