Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Help me find this 8pin touchpad connector
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help me find this 8pin touchpad connector (Read 407 times)
andrialca
Newbie
Country:
on:
January 27, 2025, 07:39:18 pm »
Hi everyone, this is my first post, and I need some help.
I recently salvaged an Asus ZenBook 14
UX425JA
that had liquid damage. A part of the board controlling the fans, speakers, a USB-A port, and the microSD reader burned out, but I’ve already found a replacement.
The bigger issue is the 8-pin touchpad connector on the motherboard, which is also burned. The damage is on the plastic part of the connector and the connector itself. The traces on the motherboard seem fine to the naked eye.
Does anyone know where I could find a replacement for this connector? I’m attaching photos for reference. Thanks in advance!
Logged
ahsrabrifat
Regular Contributor
Country:
Re: Help me find this 8pin touchpad connector
Reply #1 on:
January 29, 2025, 05:41:43 pm »
You can search at digikey.
Logged
andrialca
Newbie
Country:
Reply #2 on:
January 29, 2025, 08:04:45 pm »
i can't find any similar one, what specifically i should search for?
Logged
inse
Super Contributor
Country:
Reply #3 on:
January 29, 2025, 08:12:09 pm »
FFC connector, # of pins and pitch (probably 0,635mm, measure with caliper) and whether contacts are top or bottom.
The board is also damaged, do you feel confident fixing it?
Last Edit: January 29, 2025, 08:14:02 pm by inse
Logged
andrialca
Newbie
Country:
Reply #4 on:
January 29, 2025, 08:13:09 pm »
i would like to try at worst it doesn't work like it does now, right?
Logged
inse
Super Contributor
Country:
Reply #5 on:
January 29, 2025, 08:16:11 pm »
buona fortuna!
If you are not used to this kind of soldering job, buy a couple more of them.
You will need a flux pen and solder wick, hot air would be beneficial.
No pencil type soldering tip, small chisel preferred.
Last Edit: January 29, 2025, 08:20:28 pm by inse
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
