TL;DR: I'm looking for a "goldilocks" transistor that will switch a constant load of up to 1500mA at 2.7vHi folks, apologies for the very basic question. I'm designing a replacement driver circuit for some 33' fairy light strands.
My design goals are
1. I would like the lights to be dimmable
2. I would like the lights to be powered off a microUSB port, so I can use any old microUSB cable as an "extension cable"
3. I would like to be able to control the lights with my phone
4. I would like to have enough current headroom so as to be able to swap out the 33' light strands for a 50' light strand, should the need arise
So, from that, we're working with the following assumptions
- source voltage will be 5V (because USB)
- the microcontroller I'll be using for PWM dimming will be an ESP8266, which has a nice BLE stack for the phone control and an easy-to use sleep mode to minimize power consumption when in "off" mode.
The strands themselves are harvested from a commercially available Chinese part (
https://www.amazon.com/gp/product/B01KL9KVCQ/) sourced via Amazon. The stock driver board runs them at ~700mA, with a 2.7V drop across the LEDs. I plan to use an appropriate 1/2W current-limiting resistor to drive these LEDs from a 5V source at the appropriate current & voltage.
This is, obviously, a pretty simple circuit. GPIO pin, transistor, resistor, done.
The bit where I need help is part selection for my transistor. Since I'd like to build in at least 2x headroom for current in order to be able to drive a longer LED strand, I need a transistor that can switch a constant load of ~1400mA at 2.7v.
In the past, I've always used the plain-old PN2222 for this kind of thing, however it's only good up to around 500mA based on the datasheet. It seems like the next step in terms of "standard hobbyist parts" is something like a TIP120 Darlington transistor, but they seem massively overkill for this project (I definitely do not need 5A at 60v!).
Any recommendations for an appropriate part for this application? Preferably something available in both a thru-hole package for prototyping, and a SMD package for final assembly (SOT-23 would be ideal).
