Yes, YOU CAN DO IT......
(I knew it
You have only ofended yourself but it is allright now..."errare humanum est, perseverare diabolicum"
About your schematic: The original schematic of Rodrigopires is from an application note of SGS-THOMSON.
http://www.iascaled.com/docs/psu-400w/an308.pdfIt is intended to be a non isolated low cost circuit without transformer and without optocoupler.
If you choose the new 3 quadrants snubberless triacs, this circuit works very well with low power motors and transformers.
You must remember that Rodrigopires is making a welding machine with free MOT transformers and he is looking for the lower cost possible.
If you choose a more expansive solution with isolated control, there are hundreds, perhaps thousands of possible solutions.
To trigger the triac, you can use a triac optocoupler as a MOC3023 or you can use a pulse transformer
In this case, with inductive load, you must have a pulse train to trigger the triac.
In your schematic, you can't use a bridge rectifier with a SCR instead of a triac.
The SCR will probably stay fully conducting with inductive load without any control.
Choose a new 3 quadrants triac, they have a high dV/dt caracteristic adequate for high inductive load.
The photo-triac of the MOC3023 has a lower dV/dt, read the application note to see the right schematic to protect it from high dV/dt.
SCR need also a 470R resistance between gate and cathode.
All the schematics are generally comparing a dc adjustable voltage with a 100 or 120 Hz sawtooth sincronised with mains to generate the triggering pulses.
This may be done with µc, dedicated IC as TCA785 (absolete), OP amp, 555, ....
If you use bipol 555, you can't use 3 output pin to drive directly a transistor as you did, you need a resistance between base and emitter of this transistor.
You should also provide a softstart to prevent saturating the transformer.
