Author Topic: Teensy 3.2, Turbine EDF27 and Turnigy Plush 6A speed controller  (Read 2421 times)
Offline NexoTopic starter
  • Country: co
Hello everyone!
I'm building a line following using a Teensy 3.2 (which can be programmed with the Arduino's IDE) and I want to implement the turbine showed below:
Turbine EDF27: https://hobbyking.com/en_us/edf27-with-11000kv-motor-assembled.html
Turnigy Plush: https://hobbyking.com/en_us/turnigy-plush-6a-8bec-6g-speed-controller.html
Nothing I've found on forums seem to work so I'm here asking you guys.
The code I show below is the one I'm using but is not working. A friend of mine connected a potentiometer and started moving it and the turbine worked but I don't know how to do it merely by code. Any idea will be very appreciated.
Code:
Coded by Marjan Olesch
Sketch from Insctructables.com
Open source - do what you want with this code!
#include <Servo.h>
int value = 0; // set values you need to zero
Servo firstESC, secondESC; //Create as much as Servoobject you want. You can controll 2 or more Servos at the same time
void setup() {
  firstESC.attach(6);    // attached to pin 6 I just do this with 1 Servo
  Serial.begin(9600);    // start serial at 9600 baud
void loop() {
//First connect your ESC WITHOUT Arming. Then Open Serial and follow Instructions
  firstESC.writeMicroseconds(value);
  if(Serial.available())
    value = Serial.parseInt();    // Parse an Integer from Serial
NOTE: I don't want it to vary its speed yet, I only want it to work at a set speed.
Thanks in advance!
« Last Edit: October 05, 2017, 02:50:17 pm by Nexo »
  • Country: co
Re: Teensy 3.2, Turbine EDF27 and Turnigy Plush 6A speed controller
« Reply #1 on: October 05, 2017, 07:04:24 pm »
I've done it! I found a site where there was a code and used it:
(Site: https://www.instructables.com/id/How-to-run-an-ESC-with-Arduino/)
//This code can be used for any purpose.
#include <Servo.h>
Servo ESC1;
int pos = 0; //Sets position variable
void arm(){
setSpeed(0); //Sets speed variable
delay(1000);
void setSpeed(int speed){
int angle = map(speed, 0, 100, 0, 180); //Sets servo positions to different speeds
ESC1.write(angle);
void setup() {
ESC1.attach(6); //Adds ESC to certain pin.
arm();
void loop() {
int speed; //Implements speed variable
for(speed = 0; speed <= 70; speed += 5) { //Cycles speed up to 70% power for 1 second
setSpeed(speed); //Creates variable for speed to be used in in for loop
delay(1000);
delay(4000); //Stays on for 4 seconds
for(speed = 70; speed > 0; speed -= 5) { // Cycles speed down to 0% power for 1 second
setSpeed(speed);
delay(1000);
setSpeed(0); //Sets speed variable to zero no matter what
delay(1000); //Turns off for 1 second
I hope it helps someone. Have a great day!
Offline Leev
« Reply #2 on: February 21, 2018, 07:11:38 am »
Hey!
Can confirm this code works with my particular ESC. Was having problems arming a Turnigy ESC Plush30a for a brushless motor before running this code. I added a longer delay at the start which also may have given my ESC enough time to arm.
void arm(){
delay(8000);
Thanks to Nexo for the help. If you ever come to Australia I'll shout you a beer :)
  • Country: co
« Reply #3 on: September 01, 2018, 07:53:31 pm »
Glad it worked for you!
Looking forward to that beer  ;D
