I need some help deciding if my battery characterization setup will work properly.
Background: I have a few different single cell LiPo batteries (3.7V). I want to characterize them using similar loads that my circuit will use.
Setup: I will use three LiPo's with each having a separate programmable load. I want to use arduino to log the battery voltages and to halt the discharge of each battery when they go below 2.7V. Attached is a schematic. Are there any concerns about having the three loads connected to the same ground? Should I use DPDT relays instead?
