[ 5713.313402] usb 3-1: new full-speed USB device number 4 using xhci_hcd
[ 5713.509587] usb 3-1: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 5713.511652] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
paul@localhost ~ $ ls -l /dev/ttyACM*
crw-rw---- 1 root uucp 166, 0 Feb 6 19:37 /dev/ttyACM0
On mine: Ubuntu-gnome 16.04.3 LTS
Arduino IDE installed from the Ubuntu Software Center, IDE version 2:1.0.5+dfsg2-4
UNO plugged in to a USB port, then start IDE, in Tools select Board = UNO, Programmer = AVRISP mkII and in Serial Port select /dev/tty/ACM0
works for me
note that the UNO must be plugged in for the ACM0 selection to show up
Well, so what? Installing from the Software Center is easy and fast and does not require compiling from scratch, and the IDE does everything I need it to do and is compatible with all of the hundreds of sketches in my six sketchbooks. Not only that but it appears that my post may have been actually helpful to the OP.
Back in my old *nix classes we learned to always add double the swap as ram installed. Maybe adding more swap space would help increase the performance.
swap is virtual memory that utilizes hard drive space. Id set the swap to 8gb... In my humble opinion, I would imagine it will help.
It's as old as the hills that advice. It stems back to when machines had in the order of 256Mb of RAM. With the 32bit machines reaching to 2Gb it became defunct. You can't have more than 4Gb of total RAM and swap on 32bit. You can create it, but it won't be used.
On the other hand, any pointers how to make this damn netbook run half decently.
Jeez, even Lubuntu crawls on this speed demon, should i try a different distro?
Mint maybe? I meand lubuntu runs better than the win7 that originally came with it, but just marginally. :(
I gave it a SSD instead of the HDD, upgraded ram to 4G, the beast stil crawls. >:(
The Linux kernel includes full PAE-mode support starting with version 2.3.23
Apologies, I kinda excluded that after I got burnt by the WindowsXP implementation of same. There was a bug which caused invalid address application lock ups which pretty much meant my XP install was useless once i went to 4Gb of RAM. Anything memory intensive like Flight Sim would run into the bug at some point and lock up a few hours into a game.
I never tested the Linux version as my Linux box never needed the 4Gb.
Come on... I do not think you really have anything to apologize for :)
I usually make much worst mistakes and more often than I'd like...
I don't think it is your RAM. I've been running Ubuntu (not lubuntu, actual 'heavy' ubuntu) on an i5 2nd gen with 4GB RAM, 8GB swap, SSD for a long time and Arduino runs just fine. The machine is quite breezy. If anything, it is probably your CPU.
Adding an SSD was probably a good idea, I doubt you can make the machine any better.
