I see the programmer approach again......
I understand the circuit: you have 33mV per division. Whats the accuracy needed?
Ok if you are electronic based. Do you know how this circuit works? Please explain the hardware? If you do, I will help you.
You are mistaking something here. You want to measure "150ADC" from a "5VDC" power supply?Please provide a circuit.
Yes you buy these things called sensors, you power them with 5V and put a big fat wire through them and the sensor measures the current in the wire and outputs a reading in 0-5V scale, an example of such is here: https://www.mouser.co.uk/datasheet/2/397/L01ZXXXS05-274998.pdf
Well i don't have much choice. It is the best sensor I can find as it only requires 5V not +/-15V like many. It is bidirectional so it's more like 0.3A resolution which is still fine.My boss has just decided he does not want the power measurement anymore because the customer cannot remove it from the system easily so it's not even a problem anymore.
So has the project been shelved now?
.... which is what they now want.
Quote from: Simon on December 06, 2018, 07:32:12 am.... which is what they now want.Ah, the moving target lives on. Murphy just loves those.
