Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Where are the PWM controllers for the VRMs on this graphic card?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Where are the PWM controllers for the VRMs on this graphic card? (Read 1939 times)
TheGenesis
Contributor
Country:
on:
November 05, 2018, 09:42:01 pm »
Please, someone help me to find the controller for the GPU and the RAMs.
By just guessing i would say the controller for the GPU is the "ON NCP4205" on that little daughterboard on the left ... right?
And is this thing controlling all the 6 phases (coils and drMOS's) in the middle?
But where are the VRMs for the VRAM?
Thanks in advance.
Thom
Last Edit: November 05, 2018, 11:50:54 pm by TheGenesis
Logged
aheid
Regular Contributor
Country:
Re: Where are the PWM controllers for the VRMs on this graphic card?
Reply #1 on:
November 05, 2018, 10:03:06 pm »
I'm gonna go out on a limb and say there probably are no psychics or anyone with a crystal ball here...
Did you forget to attach some pictures or some links?
Logged
TheGenesis
Contributor
Country:
Reply #2 on:
November 05, 2018, 11:51:53 pm »
Sorry ... and now with the pic
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #3 on:
November 06, 2018, 04:34:13 am »
Yes, NCP4206 is probably the controller, which is going to be VCORE I guess (1.1V or thereabouts)?
IO supply is probably U14, whatever it is. I don't recognize the code, and there's no MFG mark... could be anyone...
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
radioFlash
Regular Contributor
Country:
Reply #4 on:
November 08, 2018, 01:59:09 am »
There are six large inductors sitting next to chips marked SIC780: "The SiC780 is an integrated power stage solution optimized for synchronous buck applications..."
https://www.vishay.com/docs/63788/sic780.pdf
Logged
Chris_S
Newbie
Country:
Reply #5 on:
November 08, 2018, 03:31:00 am »
The 2 small phases between the large inductors are your VRAM VRM.
So the 2 R33 inductors, 4901NF Mosfets, and the surrounding components. The actual controller should be right below the r2r cap.
You are correct about the other phases for the actual GPU.
Logged
TheGenesis
Contributor
Country:
Reply #6 on:
November 08, 2018, 08:36:58 am »
Ok ... thanks.
I have already fearedif the little ic marked "OT=FF -H2B" would be the controller ... i couldn't find any information of that piece.
Mhmm ... three of the GPU Mosfets are shorted.
Can someone tell me, what should I expect, when measuring the resistance of the inductors?
My Multimeter shows open-line on everyone. Is it possible that my Multimeter is not accurate enough?
Last Edit: November 09, 2018, 08:54:18 pm by TheGenesis
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
