Author Topic: Some questions about Far Infrared diodes  (Read 3207 times)
Offline mistercrisTopic starter
« on: March 13, 2017, 02:44:59 pm »
I'm trying to find out info on these things in a newbie friendly format and having some issues.
I'm trying to find out a few very specific things before I go in (in order to see if they'd work for the project I had in mind).
1) Can they be set up into a "flashlight" like concept? That is, have them emit in a more or less columnar beam?
2) I understand they "heat" some material but not others. Would they warm up glass? Plastic? If the material is translucent, does it's color matter? (For example, how much of a difference would a green tint glass have on things?).
3) Is there anything special about mounting these things or is it pretty much the same as LEDs?
I'm trying to find ways to heat various things (water, metal, plastic) through an intermediary medium. I'm talking small objects and small amounts of heating here (not trying to heat a room or anything) but do it without affecting the intermediate medium. A good way of thinking about it is imagine a piece of metal in an enclosed glass box. You can shoot a laser through the glass that melts the metal and not the glass (well for short bursts anyway). I want to do something similar but with FIR.
Is it possible?
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Some questions about Far Infrared diodes
« Reply #1 on: March 13, 2017, 03:53:24 pm »
Induction heating would seem a better option for this
Day Job: Mostly LEDs
Offline CatalinaWOW
« Reply #2 on: March 13, 2017, 04:11:41 pm »
There is no simple answer to your question, other than that far infrared diodes that I am aware of are relatively low power and will not heat anything much by radiative transfer.
For a slightly longer answer, your question breaks into several parts.  First, long wave infrared is not a precisely defined term.  It frequently means radiation with a wavelength from roughly 6 micrometers to roughly 14 micrometers, but other definitions exist.
Second, the transparency of materials varies widely, and often varies widely over this band.  Materials which are relatively transparent a 6 micrometers may be totally opaque at 10 micrometers.  You need to know the wavelength of the diode you propose using, and the specific material you propose for a window to answer your question.  Many plastics are relatively transparent over parts or all of this band, but it varies with the specific mix of plastic.  It is often easier to measure the transmission than to find the exact recipe of a piece of plastic and find transmission measurements made by someone else.  Also relatively transparent does not mean 100%.  70% transmission would not be an unusual value.  If you were to find a source which could do significant heating (10 W as an example), it would deposit significant heat (3 W in the example) in the window.  This isn't necessarily a problem to the window, since you can arrange the beam size to be large as it goes through the window, resulting in low power density.
Third, the absorbtion of materials also varies widely with wavelength and surface treatment.  You will again need to compare your sources wavelength with the proposed target.  But a general comment is that the reason that metals get so hot sitting in the sun is that they are relatively good at absorbing the shorter wavelengths (.3 micrometers to 2 micrometers) that compose most of sunlight while they are poor radiators (which implies poor absorbtion) in the 6 micrometer to 14 micrometer wavelengths where room temperature objects radiate most of their heat.  So your long wave source is unlikely to be an efficient heater of metal targets.
« Reply #3 on: March 13, 2017, 04:29:04 pm »
..and if IR is the answer, what's wrong with a simple heater ? Going to be easier and cheaper than any exotic LED.
« Reply #4 on: March 14, 2017, 01:54:14 am »
Thanks catalinawow, that's the sort of answer I'm looking for. Couldn't find anything (that I understood at least) googling.
Mikeselectricstuff, a normal heater (of any type) isn't what I'm after. Can't have anything in the container other than the thing being heated.
I'm trying to create heat in a container WITHIN a container (if you can visualize it) but doing it remotely vs with a physical connection. I thought of FIR after happening across a description of those IR saunas and how they work. Thought that the concept might carry over.
I also thought of using something like those wireless chargers or induction heaters but I'm not sure if I'm confident playing with that kind of power requirements.
It's not "for" anything just an experiment I'm trying to satisfy my curiosity if it CAN be done with my limited knowledge of electronics.
« Reply #5 on: March 14, 2017, 02:12:11 am »
One of those nice dangerous 1-3w blue laser diodes/pointers  might be an easy option. it will go through glass just fine ( just watch for the reflections)  and be absorbed nicely on a matt black surface.
Offline KE5FX
    • KE5FX.COM
« Reply #6 on: March 14, 2017, 03:03:20 am »
Any IR diode with enough power to cause noticeable heating isn't going to be eye-safe.
« Reply #7 on: March 14, 2017, 03:18:39 pm »
To answer the question, at least as where to get them, ebay and amazon - entering far infrared diode - gets a bunch of hits.
I'd read the marketing wank from one of those IR saunas and then had found those listings on amazon so combining the two bits of info I thought it'd be able to do what I wanted given the small scale I was thinking.
Thanks all, you def saved me a few bucks on parts with your answers! This is why it's worth asking those who know.
Offline Gregg
« Reply #8 on: March 14, 2017, 08:19:51 pm »
If the purpose to heat a small sample inside a container is to do so in an inert atmosphere, I would consider modifying one of the cheap 858 hot air soldering devices to use nitrogen instead of air.  I don’t know how available nitrogen cylinders are in your country, but the common suppliers are industrial welding and commercial refrigeration outlets.  This would be similar to the way inert gas is used in TIG welding but with a different heat source.  An inexpensive ebay regulator with a flow meter attached would be a good idea to minimize wasting the nitrogen.  A lot of gas flow isn’t necessary except to keep from burning up the heating element.  Carbon dioxide may work, but it is a pretty good refrigerant on its own and may require more heat input.  The beverage industry [beer and soft drinks] uses CO2 as well as paintball etc.  Argon is a staple in TIG welding and for all practical purposes completely inert.
Offline CatalinaWOW
« Reply #9 on: March 14, 2017, 08:28:52 pm »
Checking the Ebay listings it seems clear that there has been some slippage going back and forth from English to Chinese.
These diodes are far red (usually called near IR).  Some of the listings call them far infrared.
Lots of window materials will transmit this readily, but not all glasses or plastics - you have to check what you are using.  But it is easy, since transmission at these wavelengths is far more available than for longer wavelengths.
Most metals and metal finishes absorb these wavelengths well, so a heating application might work.  May or may not be the best approach depending on the other things going on around your idea.
The ones on Ebay have enough power that eye safety is a real issue.  Since you can't see them real damage can be done without you realizing it.  Keep yourself and other people safe.
« Reply #10 on: March 14, 2017, 09:08:47 pm »
It doesn't need to be IR to heat.
As I said, a blue laser is going to be the cheapest & easiest way to get some heat into a glass-enclosed object. Easily enough to set things on fire.
Offline raspberrypi
« Reply #11 on: March 15, 2017, 02:35:01 am »
Where do you get one of those in a "laser pointer" format? I have a green one, but you have to focus it and the color of the object you are trying to burn is important. I call it the raciest laser pointer, because I like to aim it at my skin and say its safe, then aim it my friends who are different shades of black and they yell out in pain when I turn it on.
I don't mind spending a hundred bucks on it, but for that kind of money I want to be sure what it is. The green laser was only 10 bucks but the same thing sells as high as 60 or 70 and I don't want to get "burned".
Oh and what are you making? It sounds interesting. LEDs dont put out much power. Ever tried to feel the heat off your TV remote control?
Any more plane crashes near your house? ;)
« Last Edit: March 15, 2017, 02:36:37 am by raspberrypi »
I'm legally blind so sometimes I ask obvious questions, but its because I can't see well.
« Reply #12 on: March 22, 2017, 02:10:18 am »
catalinawow, you wouldn't happen to have some info on this would you? I had no idea eye safety would be an issue on these things so I would've for sure messed myself up on it. Any links would do (not TOO technical if possible. I can go through the more technical stuff but it's slow going).
At present I'm trying to heat a small item (can be any material frankly as long as it's small) inside a water filled container inside a water filled pot. I was planning on sealing all items but now I'm concerned about reflections off the glass.
Offline CatalinaWOW
« Reply #13 on: March 22, 2017, 05:36:06 am »
I haven't located any good current summary documents on eye safety, and don't seem to find any of the older ones in my files.  The following links are the best so far.  Although the first is specifically for lasers, the damage to human eyes is not dependent on the coherency of the light, only the intensity.
https://www.osha.gov/dts/osta/otm/otm_iii/otm_iii_6.html
This second link gets you to a page where you can download the actual document.
http://ec.europa.eu/social/main.jsp?catId=148&langId=en&pubId=5926&type=2&furtherPubs=yes
The problem with infrared light is has many facets, all related to the fact that your visual system doesn't activate it's protective mechanisms in response to this light.  You don't blink, you don't look away and the iris doesn't shrink down.  Real damage can be done before you realize there is anything to worry about.  The near IR is worse than longer wavelengths because it still focuses very much like visible light, producing the highest energy densities right at the retina.  Longer wavelengths (even 1.5 micrometers helps) tends to focus short of the retina.  The clear gel that fills our eyes is harder to damage than the retina.
