Author Topic: Arduino Schematic HELP!  (Read 13555 times)
Offline retrolefty
Re: Arduino Schematic HELP!
« Reply #50 on: October 03, 2016, 08:35:20 pm »
Ok, new question, i ordered in a arduino nano. i tried to find a low power mode library or something. sadly, i couldn't find anything. Do you guys know of any ways to get lower power consumption without removing the leds? or am i better off using my Uno?
 Well the power on led is not under any kind of software control so sleeping won't do anything for it.
Offline skillz21Topic starter
« Reply #51 on: October 08, 2016, 04:59:49 am »
sleep mode will at least save a bit of power.
Offline sleemanj
  • Professional tightwad.
« Reply #52 on: October 08, 2016, 05:19:01 am »
Kill the leds.  If you are not using the onboard regulator cut it's legs (the cheap AMS1117 regs from china have a high quiescent even if you're powering after the reg).  If you don't need the ADC, shut it down.
« Reply #53 on: October 08, 2016, 11:22:00 am »
ok, i might do that :D. i havent actually gotten the arduino yet, so i'll test it out when i get it.
Online Ian.M
« Reply #54 on: October 08, 2016, 06:27:37 pm »
Rather than butchering Arduinos, why not start from an ATmega328P chip, flash it with an Arduino bootloader then program it via a USB <=> logic level serial cable?
That way you don't have to hack off LEDs or regulators and you can easily isolate the MCU to check its power consumption.
There's even a page about doing this at Arduino.cc
« Reply #55 on: October 08, 2016, 11:27:00 pm »
Thats actually a good idea :)
