Author Topic: Avago/Broadcom - PCIe Switch Datasheet???  (Read 2174 times)
Offline TantalumTopic starter
« on: May 28, 2016, 10:56:53 pm »
Hello
Why are the datasheets from Avago/Broadcom not available publicly?
I actually wanted to determine how difficult it would be to implement a PCIe switch on a PCB. I needed a reference design, a BOM and find out if those chips only needed basic configuration data in an eeprom or if they needed to be programmed from scratch.
I can't understand why those information aren't available, there is absolutely no secret or strategic important information about their products in those datasheets.
« Last Edit: May 29, 2016, 06:58:21 am by Tantalum »
Offline amyk
Re: Avago/Broadcom - PCIe Switch Datasheet???
« Reply #1 on: May 29, 2016, 02:48:36 am »
Short answer: Because they're a bunch of uptight b*stards. You can find datasheets for PCIe switches from IDT here:
http://www.idt.com/products/interface-connectivity/pci-express-solutions/pci-express-switches
e.g. here's one
http://www.idt.com/document/dst/89hpes16nt16g2-datasheet
If you search around their site you'll find more information on them. Look for "user manual" or "hardware design guide".
« Reply #2 on: May 29, 2016, 07:00:29 am »
Actually I was looking for a PCIe gen3 switch, 16 lanes 5-6 ports.
Only PLX/Broadcom has such ones :/.
Offline Kalvin
  • Embedded SW/HW.
« Reply #3 on: May 29, 2016, 01:20:10 pm »
Try to find reference designs or open sourced designs that contain the devices you want to use. Maybe that will help you to get started.
Offline amyk
« Reply #4 on: May 29, 2016, 03:50:57 pm »
IDT has some, looks like you need to register to download from their site but you can find the datasheets elsewhere too:
http://www.datasheetlib.com/datasheet/1428418/89h32h8g3_idt-integrated-device-technology.html
« Reply #5 on: May 29, 2016, 07:03:16 pm »
Yes I know, they have 3 such switches but:
1. They are too huge 32 lanes,  those bga chips have between 484 and 1156 balls.
2. All 3 are marked as "obsolete"
