Author Topic: Arduino solid state relay  (Read 3569 times)
Offline House91320
« on: October 02, 2010, 03:50:28 am »
I am trying to get this ssr to work with my arduino but it just is not happening anyone got an idea why
http://www.tycoelectronics.com/catalog/pn/en/1393030-4
Offline Time
Re: Arduino solid state relay
« Reply #1 on: October 02, 2010, 04:27:17 am »
You need to provide more information about how you are trying to do it.  Schematic, etc.
-Time
Offline thakidd
« Reply #2 on: October 02, 2010, 05:00:56 am »
Hey House...Been working with the Arduino for a while now. I took a look at the link you provided. It appears you are trying to use the SSR-240A25 model of this SSR. I took a look at the spec sheet and noticed that the specific model you are looking at requires an input voltage of 90-280VAC. This is what the 'A' stands for in the part number.
Check out the spec sheet I linked above..you will notice on the second page of the PDF that you want the D version of the SSR which provides an input voltage of 3-32 VDC. I am guessing that would be the SSR-240D25. Make sure you spend 5-10 minutes checking out that spec sheet as that will make or break your project.
With an input voltage of 3-32VDC, you should be able to plug this guy in to whichever pin and ground on the arduino and get results. Hope that helps.
« Last Edit: October 02, 2010, 05:03:13 am by thakidd »
Offline House91320
« Reply #3 on: October 02, 2010, 05:04:30 am »
FAIL on my part.
thank you
« Last Edit: October 02, 2010, 05:13:31 am by House91320 »
Offline thakidd
« Reply #4 on: October 02, 2010, 05:16:09 am »
No worries...I have made that mistake more times than I have fingers and toes. Keep it around though..when you least expect it, that part will come in handy!
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: October 02, 2010, 12:32:32 pm »
FAIL on my part.
thank you
actually you have succeded... to admit your mistake, not all people can do that ;)
« Last Edit: October 02, 2010, 12:43:51 pm by shafri »
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
