Author Topic: soldring iron resistance and AC leakage  (Read 8937 times)
Offline SnakeBiteTopic starter
  • Country: il
  • OBSESSED MODDER
« on: September 30, 2010, 11:56:24 pm »
Hello,
i noticed lately that a lot of manufacterers have devices that check soldering tip temperature as well as tip resistance and AC leakage.
a few questions:
1. how important is to test the tip resistance and the tip AC leakage?
2. it's important to check it dayley?
3. it i found wrong tip resistance or/and AC leakage can i fix it in some way?
thanks
Ido
Ido Aricha , Israel.
Offline JohnS_AZ
    • About.me
Re: soldring iron resistance and AC leakage
« Reply #1 on: October 01, 2010, 12:11:22 am »
For the most part concerns about tip resistance and leakage are to reduce or eliminate the potential for EOS/ESD damage of the board being soldered. Here's a really good reference...
http://www.esda.org/documents/openforumhandtoolsprass08.pdf
John ( Past President, Arizona Chapter of the EOS/ESD Association  :D )
« Last Edit: October 01, 2010, 12:13:20 am by JohnS_AZ »
I'm either at my bench, here, or on PokerStars.
Online Zero999
  • 0999
« Reply #2 on: October 01, 2010, 06:29:31 am »
The electrical safety standards in the UK state that the resistance of the earth conductor of and class 1 piece of equipment must be lower than 1 Ohm (I think, it might be even lower).
Some soldering irons are powered off a transformer which is best for both ESD and safety alike. The transformer's voltage is always under 50VAC (normally 12V or 24V) so the soldering iron is considered to be a class 3 device which requires no earth connection, although some models connect the tip to earth via a 1M or 10M resistor to limit the current of ESD as well as protecting the transformer.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: October 01, 2010, 12:54:43 pm »
when we lived in italy and the house had no earth (which I later installed myself) I remember getting a tingling feeling from a board I was taking apart and eventually realized it was coming from the iron, I was rather surprised (must have been like 20mA). Problem went away when i installed an earth
Online Zero999
  • 0999
« Reply #4 on: October 01, 2010, 01:09:11 pm »
I had the same problem before the house was re-wired.
There was no earth connection in my bedroom and the earth wire had a shocking voltage/current on it until I bonded it to the radiator.
  • Country: il
  • OBSESSED MODDER
« Reply #5 on: October 02, 2010, 04:57:41 pm »
so basically i don't need this device if i got grounding in my room that what you saying?
Ido
Offline Simon
  • Global Moderator
« Reply #6 on: October 02, 2010, 04:59:57 pm »
well if your soldering iron tip is connected to earth and you have an earth connection you should be ok
alm
  • Guest
« Reply #7 on: October 02, 2010, 06:09:32 pm »
Indeed, as long as the tip is grounded, you can safely touch it ;).
Online Zero999
  • 0999
« Reply #8 on: October 02, 2010, 06:18:19 pm »
I wouldn't say a soldering iron tip, heated to over 300oC, is safe to touch.  :P
  • Country: il
  • OBSESSED MODDER
« Reply #9 on: October 02, 2010, 07:28:55 pm »
the iron i'm using is PACE MBT 250 WITH PS-70 soldering iron so i think they take care of the grounding.
thanks for all the helpers
Ido
Online djsb
« Reply #10 on: October 02, 2010, 09:36:18 pm »
Just ask PACE themselves. I don't know why you asked the question if you knew the answer already. Besides PACE has all relevant information on their website.
« Last Edit: October 02, 2010, 09:38:56 pm by djsb »
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
  • Country: il
  • OBSESSED MODDER
« Reply #11 on: October 03, 2010, 08:20:03 am »
i didn't know that the grounding of the soldering station is related to the AC leakage and the need to check grounding .
but thanks anyways
Ido
