Author Topic: how to test leaking capacitors using DMMs?  (Read 3293 times)
Offline elex_enthusiastTopic starter
  • Country: ph
  • Everything has user-salvageable parts inside!!!!
« on: November 07, 2013, 01:09:23 pm »
hi there,
im quite confused on how to test leaking capacitors using my DMM..i used to determine leaking capacitors using an analog multimeter using resistance function but i have no idea how to perform such test using a digital meter.....please give me hints..any tips would be greatly appreciated...
« Last Edit: November 07, 2013, 01:22:59 pm by elex_enthusiast »
Always learn how to break and fix things electronics!
Offline Anks
    • www.krisanks.wordpress.com
Re: how to test leaking capacitors using DMMs?
« Reply #1 on: November 07, 2013, 02:47:35 pm »
Are you referring to coupling caps leaking DC?
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: November 07, 2013, 02:53:08 pm »
Connect the DMM in series with your charged capacitor and connect both to that same voltage you charged your cap to.
The DMM has to be set to DC voltage. By knowing the input resistance of your DMM and by reading the voltage on it when the circuit settles, you know the leakage current through you cap. :)
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #3 on: November 07, 2013, 02:59:57 pm »
Why not just use the same setup with the DMM in current mode measuring leakage current directly?
Offline Dave
  • Country: si
« Reply #4 on: November 07, 2013, 03:09:06 pm »
Silly me, I just assumed his meter wasn't capable of measuring currents that low, because he was asking the question. ::)
Offline mos6502
  • Country: aq
« Reply #5 on: November 07, 2013, 07:31:26 pm »
1. Apply a voltage to the cap (a 9v battery is handy for this) and measure the current. You probably need a uA range for this.
2. Use the resistance mode. As soon as you touch the probes to the cap terminals, you should see the resistance become very low and then slowly increase into the single digit megaohm range. If your meter shows a low resistance value the cap is leaky.
« Last Edit: November 07, 2013, 07:38:37 pm by mos6502 »
for(;;);
