Author Topic: Looking for a datasheet/pinout for futaba DG10T tubes.  (Read 3358 times)
Offline BoyfinnTopic starter
« on: April 04, 2015, 07:17:55 pm »
I have some 7-segment vacuum fluorescent tubes lying around, And i would like to do something with them.
However i've found little to none information about these tubes on the internet. Does anyone know where to find any technical information/datasheets of these parts?
Here's one of about 20 results i found on google image search and they look pretty much like this:
Offline Moseven
Re: Looking for a datasheet/pinout for futaba DG10T tubes.
« Reply #1 on: April 04, 2015, 09:54:22 pm »
Use Google Translate on this page : http://www.ne.jp/asahi/shared/o-family/ElecRoom/PARTS/DISPLAY/ElecPds2.htm#DG10T
Translated : DG10T (ISEDEN) Dimensions ?10 × H35 mm display size W5 × H8.5 mm
Power (current) filament 1.0V 66mA grid 12V 2.8mA segment 12V 110uA (measured value).
Those numbers are also here : http://www.radiomuseum.org/tubes/tube_dg10t.html
On that page are also the connections.
This is a clock with the DT10T :
Using them is like any any other VFD : http://www.instructables.com/id/IV-11-VFD-Clock/?ALLSTEPS
« Reply #2 on: April 05, 2015, 08:44:42 am »
Thanks! This helps alot!
