Author Topic: are PC power supplies insulated from earth?  (Read 1456 times)
Offline ELS122Topic starter
« on: January 12, 2020, 04:20:13 am »
stupid question but is the ground in my pc connected to earth?
Offline wraper
  • Country: lv
Re: are PC power supplies insulated from earth?
« Reply #1 on: January 12, 2020, 04:22:05 am »
Of course it is. There is 3 prong mains connector in PSU for a reason.
The following users thanked this post: ELS122
Online Zero999
  • 0999
« Reply #2 on: January 12, 2020, 10:24:38 am »
Are you talking about the 0V rail? If so, I believe it's normally connected to earth.
Offline Brutte
« Reply #3 on: January 12, 2020, 11:04:00 am »
That depends on the design of power supply.
If your PC is desktop and it is connected to three-prongs mains receptacle then yes.
But if this PC is a laptop with two-prongs(end to end) supply, or a laptop with three-prongs(end to end) supply connected to unearthed mains receptacle then the answer is: the only connection between earth and GND is via capacitive coupling of a transformer (<1mA) and MOV(>1kV).
Of course this "floating" does not include a situation when you use two-prongs mains supply and ground laptop through USB shield to your printer which might be earthed.
The following users thanked this post: hsn93
« Reply #4 on: January 12, 2020, 05:06:48 pm »
well yeah, now it seems obvious. I just had a brain fart moment I guess.
and also I found out that if your laptop power brick has a square on its label and it has a 2 prong chord it's insulated from the mains, including earth.
otherwise, if it doesn't have that box and has a 3 prong chord it's not isolated!
« Last Edit: January 12, 2020, 05:08:35 pm by ELS122 »
Offline Brutte
« Reply #5 on: January 12, 2020, 08:53:24 pm »
(..) square on its label (..)
This is class II protection class although I am not sure if this guarantees that the secondary side is unearthed..
Offline Etesla
« Reply #6 on: January 13, 2020, 02:22:25 am »
Yes, but if your intention is to break this connection (for example to hook up multiple power supplies in series for a higher voltage  ;)), it is certainly possible.
« Reply #7 on: January 13, 2020, 04:08:36 am »
No, I just am troubleshooting noise from a interface.
Offline pcmad
    • module web design
« Reply #8 on: January 13, 2020, 11:04:59 pm »
yes earth ground  is the same as chassis ground on a desktop pc
