These chips have to be used in class, so if I select MCU, it means that I should write a code, then get chips, program them, make tests, etc. Why should I bother, if there's a ready made solution available?
I checked the chinese suppliers, and knock off SN74LV8153 is available for around 50 cents, so here we go, and thanks for suggesting it!
