Author Topic: Black powdery residue after changing tip  (Read 162 times)
Offline fixit7
« on: June 05, 2019, 03:06:48 pm »
When I changed my tip to a different type on my Chinese copy of a Hakko, I saw a small amount of black powdery residue that came out.
I have used the soldering around 50 times. Is that part of a carbon rod?
I plan on getting a better iron that actually maintains the right temp.
Thanks,
          Andy
Offline bob91343
Re: Black powdery residue after changing tip
« Reply #1 on: June 05, 2019, 04:28:11 pm »
That's just oxide accumulation, very normal.  Clean it up for best results, as it's not as good a heat conductor as metal.  In the long run it can build up enough to make the iron less effective.
The following users thanked this post: fixit7
