Author Topic: Sziklai pair power series pass setup  (Read 1048 times)
Offline sahko123Topic starter
  • Country: ie
« on: April 01, 2020, 12:13:51 am »
All i want to know simply, is a sziklai pair with say a generic pnp transistor with a tip3055 power npn acting as a negative pass element possible or should i just get the complementary tip2955? This pair will be used as a negative voltage regulator.
Asking for a friend
Online T3sl4co1l
    • Seven Transistor Labs
Re: Sziklai pair power series pass setup
« Reply #1 on: April 01, 2020, 12:19:59 am »
Yes.
Seven Transistor Labs, LLC
  • Country: ie
« Reply #2 on: April 01, 2020, 01:28:41 am »
as amazing as the answer was where the sign-off takes more characters than the answer could i know to what question it was addressed? What i essentially want know is does sziklai pair essentially change the type (npn/pnp) of the transistor regardless of power.
Asking for a friend
Online T3sl4co1l
« Reply #3 on: April 01, 2020, 02:41:46 am »
You asked if it's possible, or some alternative; yes, it is absolutely possible, so no alternative is needed.  You hadn't indicated what else you're lacking, so...
The type of the Sziklai pair is defined by the input transistor, yes.  The input transistor only needs to be rated for the base current required by the output transistor, and both need to be rated for operating voltage and power dissipation.  Some typical caveats include potential for oscillation, and proper design of current limiting or other protective means.
Oscillation can happen for a combination of reasons: the input transistor is typically rated for less current and more fT, while the output transistor has a lower fT, longer lead lengths and higher capacitances; this introduces more gain and phase shift in the C-E path of the input transistor, which can push the combination into oscillation.  Whereas a Darlington has Miller effect (C-B feedback) and emitter degeneration (the one emitter is cascaded into the next base).
Note that an emitter resistor on the output transistor essentially accomplishes nothing.  If an emitter resistor is used for degeneration or limiting, it goes on the composite/equivalent emitter terminal.  Which is obvious when drawn with the equivalent/composite, but it's been missed before...
Online David Hess
  • DavidH
« Reply #4 on: April 01, 2020, 02:59:35 pm »
Before good and economical silicon power PNP transistors became available, it was more common to use Sziklai pairs for negative regulators and for the negative side of class-AB audio power amplifiers.  Search for "quasi complementary power amplifier" to find examples.
