When a V-O-M says 10k Ohms/Volt, it means 'volts full scale'. If you are on a 1V scale, the input resistance is 10k * 1v or 10k Ohms. If you are on a 20V scale, the input resistance is 10k * 20 or 200K Ohms. So, without being told what scale the meter is set to, it isn't really possible to get the right answer.A better explanation is here:https://www.allaboutcircuits.com/textbook/direct-current/chpt-8/voltmeter-impact-measured-circuit/
