I am reading about Center-tapped full-wave rectifier explanation in AoE section 1.6.4 (B) - Attached references .
I find it really hard to construct/visualize what he is trying to explain in this section .
Here's what i struggle with ; typing this paragraph and the questions in parenthesis . kindly please someone guide me through this .
Center-tapped full-wave rectifier :
The circuit in Fig 1.63 ( attached ) is called center-tapped full-wave rectifier . The output voltage is half what you get if you use bridge rectifier . It is not most efficient circuit in terms of transformer design, because each half of the secondary is used only half the time ( ME:clear to point ) .
To develop some intuition on this subtle point , consider two different configurations that produce same rectified DC output voltage ( ME:clear to point , he'z going to compare two circuits )
cont..
(a) circuit in Fig 1.63( attached) and
(b) the same transformer (( ME: which same transformer
) , this time secondary cut at the center tap and rewired with two halves in parallel ( ME: i am thrown off already at this point , where did you cut and how did you join
) cont.. the resultant combined secondary winding connected to full wave bridge ( ME: What is that resultant circuit , how does that look which is connected to full wave bridge
