Hello everyone, first post here.
Aircrafts use its metal chassis as Earth ground for several reasons, one of which is to provide a bleed path for ESD. I'm designing a PCB with the intention of putting it on an aircraft. This PCB uses DCDC isolators to create the rails I need, as well as providing ground isolation. However, there is no path to ground with isolated grounds to the chassis (obviously). I've heard that I can make high impedance connections between the grounds and chassis, but I am struggling to find any documentation (app notes/books) on that topic.
Can anyone provide some insight, or at least point me to some resources on this topic?
Thanks!!
