Author Topic: Made a simple variable relaxation oscilator  (Read 8858 times)
Offline zeal422Topic starter
« on: January 08, 2024, 06:39:14 pm »
Hey! And yes, I am still a noob in electronics, but learning... Here it is... https://i.imgur.com/FgzsZ8u.mp4 It's so cool to know the potential of these old babies, basically they're a vacuum tube (of sorts). I was thinking of making a random pattern blinking lamp but if you have more neat ideas in mind, please let me know, cheers!  :scared:
Online RoGeorge
Re: Made a simple variable relaxation oscilator
« Reply #1 on: January 08, 2024, 07:08:05 pm »
Song title?
« Reply #2 on: January 08, 2024, 07:32:44 pm »
Offline Zero999
  • 0999
« Reply #3 on: January 08, 2024, 07:41:51 pm »
A reverse bias oscillator.
Note this circuit puts the transistor under a lot of stress and will reduce its hFE, so you might not want to use Q1 for other circuits.
EDIT: I forgot, D1 should be an LED and I accidentally used a PNP symbol. :palm:
« Last Edit: January 08, 2024, 08:43:20 pm by Zero999 »
« Reply #4 on: January 08, 2024, 08:00:46 pm »
I wasn't using any transistors in this one, just straight small 18VAC variac to a reverse 12-0-12 transformer to control the mains voltage more precisely to get a variation from 0 to 260 :)
« Last Edit: January 08, 2024, 08:03:22 pm by zeal422 »
Offline Zero999
  • 0999
« Reply #5 on: January 08, 2024, 08:40:50 pm »
I know. I'm familiar with the circuit. It uses the neon lamp as a switch. When the voltage exceeds a certain point, the lamp arcs over and discharges the capacitor, the lamp goes off, once the current drops below a certain value and the cycle repeats.
The frequency of the flashing will probably vary with the ambient lighting: it'll speed up in bright light and slow down in the dark.
You said you wanted ideas, so I posted one.
« Reply #6 on: January 09, 2024, 07:08:16 am »
Oh yeah, absolutely, thank you! :) It's a pretty neat and simple circuit, I didn't know neons could be this simple yet complex
