Author Topic: LM317 - how it works ? strange REF feedback.  (Read 2235 times)
Offline boo9Topic starter
« on: February 02, 2015, 04:44:59 pm »
I have a broken PWM control board for inductive loads,  24A, input 10-40V DC (not stabilized)
There is a LM317 to supply DC to IC (IC markings are erased but I suspect SG2524) about which I have a question.
I dont understand LM317 configuration here, if someone please explain that to me.
How does the feedback voltage from OUT gets to REF pin of the LM317, there is a resistor divider, OK I follow that,  but then there is C2 cap that follows, separating the resistor divider from the rest of the cirucit, Can feedback loop work correctly with C2 placed there ? There is no current flowing from OUT throu resistor deviders, only during charge/discharge. Assuming C2 is charged to some V, can LM317 operate correctly and stabilize the V to the board ?
From what I manged to probe, the bottom connector of C2 goes to 12-13 pin of the IC (right row, two middle pins), the SG2524 has collector of two output transistors there.
cheers
« Last Edit: February 02, 2015, 08:47:54 pm by boo9 »
Offline Zero999
  • 0999
Re: LM317 - how it works ? strange REF feedback.
« Reply #1 on: February 02, 2015, 08:59:02 pm »
A capacitor is often connected between Vref and 0V to improve the ripple rejection. There's an example on the datasheet.
« Reply #2 on: February 02, 2015, 09:05:04 pm »
The C2 cap is positively not on REF/Ground pins on this board.
Offline Circlotron
« Reply #3 on: February 03, 2015, 01:40:11 am »
Maybe it is a design mistake that nobody picked up because the board sort of worked - until now - and this is the cause of the failure?
« Reply #4 on: February 05, 2015, 10:23:21 pm »
@Circlotron - you are correct, I just saw same design different board and there is a ground path from C2/R47k point.
