Author Topic: Asking for review / validation : making a very simple AC transformer box  (Read 2512 times)
Offline gwelavoTopic starter
Hello everyone,
I decided to re-learn electronics from the basics. For that, I'm currently reviewing the 6.002 MIT course while reading Foundations of Analog and Digital Electronic Circuits. I'm also following Learning the Art of Electronics while reading The Art of Electronics. My end goals are 1. play with RF, I find the subject "magical" and 2. better understand the digital world as a Software Engineer.
I didn't buy any kits for Learning the Art of Electronics, I purchased a DS1054z, a DP832, and a SDG 1025 a few years ago when I thought I would have the time to learn (I got 3 kids in the meantime, I think I'm good to go now).
I managed to move forward in the last 2 weeks without much of a struggle even though I don't have access to a 6.3 AC transformer. I combined the 2 outputs of my function generator to produce a 60 hz signal with 10 khz noise on top of it with success (I know the amplitudes changed).
Now I still find the exercise of making a box for such a transformer fun... So I bought this: https://docs.rs-online.com/714b/A700000008857720.pdf and everything on the bench in the attachments. I made a very crude schematic of how I want to plug the transformer with the fuse box and the switch. I assumed the phase is the best line to place both the switch and the fuse box.
The transformer will be mounted on a 0.75 mm thick piece of steel, grounded, to secure it to the box.
Is the plan sound ?
If I understand things correctly, I will have access to 6.3 Vrms A.C. between COM and the other two plugs and 12.6 Vrms between the two plugs (read and green). Is that correct?
Sorry for the dumb questions, this is still new to me.
Kevin
P.S.: This is my first post on this forum, I don't know if I must introduce myself somewhere.
P.S. 2: I fucked up when ordering the banana plugs... that's why I have a green and a gray instead of 2 reds and a black  |O
Online tooki
It’s fundamentally correct as you describe.
However, I’d suggest a few changes:
1. Use a double-pole switch and disconnect both line and neutral, since the French plug does not enforce polarity if it’s ever plugged into a non-grounded outlet (or, for example, plugged into a Schuko outlet.) That way it’s safe no matter what.
2. Use four banana jacks and run each secondary wire separately. That will give you the flexibility to connect them in series to get 12.6V, in parallel to get 6.3V (with double the current), or to use them independently as two floating 6.3V sources.
Alternatively, you can use a DPDT switch to switch two jacks between series and parallel.
3. Get the right color banana jacks: I wouldn’t use green for anything except earth ground. You could use it as a third/fifth jack to earth ground.
4. Add output fuses. A 1.6A fuse on each secondary should work nicely. Put the fuse on each secondary before any points where you connect the secondaries together.
Thanks a lot for that!
1. Good point, the switch already support it.
2. Indeed, it will make more sense and be more "generic", I will order proper colored banana jacks  |O
Also good idea about the DPDT, I think I already have one I can use. There would be 3 positions: independent, in series, and in //. I will also need to make some sort of a sticker for the front panel to document what's what (how jacks are connected depending on DPTD state).
3.  |O |O
4. I didn't think about that. I have everything I need here.
A follow up question: Would you use fast blow fuses or slow blow fuses?
Online tooki
3.  |O |O
2. Maybe take a look at the schematics for some bench DC power supplies to see how they handle the series/parallel switching. Maybe with a multipole (3P or 4P)l 3-position switch you can have one switch that does it all.
4. It depends on your load, but I don’t think it really matters here. We mostly want to protect against substantial overcurrent, where either type is fine.
At really large overloads (e.g. 50x rated current) either type will blow practically instantly. At a medium overload (e.g. 3-10x), a fast-blow fuse blows faster than the slow-blow. But at very small overloads (e.g. 1.5x), the slow-blow fuse may actually blow faster than the fast-blow.
The thing that perhaps speaks in favor of slow-blow is that if you ever end up doing anything with motors, they often take a spike of current to get going. So I’d probably put in a slow-blow and call it a day, but if you have a fast-blow in your drawer already, use that.
I think a DP3T is good enough for my use case, see the revised plan in the attachments. I should receive the correct banana jacks today. Once it is ready, I will share the end result.
Online tooki
Nice.
Looks like you don't even need a DP3T switch, just an On-Off-On DPDT.
Online tooki
Oh yeah: one last thing I'd add, if not already present in the switch, is a power light!
The light is built into the power switch and I will in fact use a on-off-on switch as it is what I already have. I remember having this switch when I built my first few kits... 25 years ago .
Offline Jwillis
Looks good. Well done so far. I didn't notice or see a reference of double shielded power cord for the mains supply. It would be an added safety feature and it would look better.
Online tooki
Why would you need any shielding at all on the mains cord, never mind double shielding?!? The primary place you see shielded mains cords is in audiophool setups...
And shielding is not a safety feature anyway, it's to prevent noise from getting in (or out).
Offline Jwillis
Simple misinterpretation on my part. My apologies. I meant double insulated power cord. 18AWG would be fine.
Offline coppercone2
oh yeah if you put banana jacks on it put a double switch in case its ever hooked up to split phase
shielding on the cord won't do anything unless you have a fully shielded run coming from a shielded generator (gas or mechanical isolator) or possibly inverter/battery. Probobly not the cleanest power but the contents would be stable/known. And then you want a shielded connector too.
That's kind of expensive and specific. Might be useful on a ship or something that is built to have a shielded generator.
Speaking of audio does anyone have a ten ton diesel generator powering their amplifiers?
But if you have conduit runs, that are properly wired, it might do a tiny bit of filtering because the noise from the power pole wires might not get through the entire wiring network. At least certain frequencies, despite the fact that its hundreds of miles of wire. In that case a shielded cable might do some thing incredibly small. Like if its a long ass conduit run but you have a transmitter in the room, then the wire is not picking that up, and the conduit shields the main run. Very specific situation....
So basically you should just spend the money you save on a shielded cable on higher quality banana connectors and internal wiring. You can do something like splurge on teflon wire or whatever. Shielded mains cable is the last thing you need. At least nice connectors might do something lol
« Last Edit: July 25, 2023, 09:46:23 pm by coppercone2 »
Offline coppercone2
unless he means a double insulated extension cord, say rubber over something. Preferably with different colors so you can see damaged wiring (orange under black). That is a very nice feature to have in the shop, and some labs.
Offline themadhippy
yep,far too many times to remember.
Online tooki
Ah ok. Yeah, shielding and sheathing (insulation) are different things, as you know! :)
Anyhow, in Europe, single-insulated mains cable isn't allowed at all, so you always get double-insulated, even on the dinkiest 0.5mm2 (20AWG) mains cord for 3A Europlugs is double-insulated. (The only potential exception might be Christmas lights.)
Online tooki
Is it not enough to have the outer jacket (e.g. typically white, black, or gray for ordinary cable, or orange, red, or yellow for high-visibility outdoor cable) and the brown (line), blue (neutral), and striped green-yellow (protective earth) insulation of each individual conductor? You definitely see when the jacket is damaged through to the conductor insulation.
I put the cable I will use in the attachments, it is pretty standard in France and pretty much all the European countries I have resided in. For the complete reference it is 3G1,5 (3x15AWG) H05 VV-F (PVC isolation on the coper core and another layer of PVC on the 3 cables).
Still waiting for the last components to arrive... in the meantime I'm looking at how to make clean front panels. Any advice? I thought about making a sticker but I'm not sure it will be really clean this way.
Online tooki
You mean labeling it?
There are many ways. From simple labels made with a p-touch, to engraving and filling with paint, to laser etching. One method I’ve been meaning to try is one I saw not too long ago, of using a laser printer to print onto paper as a mirror image, then clear lacquer onto the panel and applying the laser-printed transfer and letting it dry before peeling off. (Unfortunately, most only show this onto wood, so I’m not sure if the absorbency of the wood is important to the process.) I’ve also seen a similar process using inkjets and aqueous acrylic lacquer.
What I have also done is use the Avery laser nameplate labels. Use a really big one that can cover the whole panel (you can just get whole A4 sheets), laser print it, and then punch or cut the holes and trim it down to size.
« Last Edit: July 26, 2023, 09:07:16 am by tooki »
Offline Wallace Gasiewicz
These days it is common to include a RFI filter on the mains input of power supplies.  You may not need it..  You can purchase them cheaply.  They come with the proper X and Y capacitors. I prefer the ones with the three prong plug.
This is what I am talking about. Not this one but a new one. Or possibly one from a discarded electronic component you have.  There are better ones  that are bigger and do not have the three pronged plug.
https://i.ebayimg.com/images/g/nLAAAOSw~KpgCgzO/s-l1600.jpg
Good idea, I will definitely use this for the next appliance. This one is for learning, I guess the less filtering at input the better the learning experience will be.
Offline coppercone2
I dunno its just a thing they do
And since its two layers you can have one that is more prone to tearing but has superior resistance properties while maintaining full safety. Overall it might lead to a longer life span. I think its usually rubber over something else.
« Last Edit: July 26, 2023, 09:43:27 pm by coppercone2 »
Progress is slow, I'm trying to figure out how to place the elements. I think I'm close. I will add more space between the banana jacks for labeling and move the selector switch close to the power switch next. The box is not wide enough to line up the banana jacks, I tried  |O
I tried the toner transfer trick on the ABS panels without success. I managed to copy Cosmo text to the panels |O I ordered some transfer paper for Laser printers to see if I can do better, my warhammer supplies might be useful afterall.
I'm now experimenting with multi-colored 3d printed panels. The fit is pretty good and the cutouts are perfect. I will try a combination of white and red as I just burned the black spool.
If nothing works, I will try to engrave black painted acrylic with my shaper origin. I never ever tried to cut something else than wood with it though.
It is alive!
I'm still waiting for the transfer paper to make a better front pannel. That will not stop me from using it and continue Learning the Art of Electronics.
Parallel and series modes are working fine. I attached what I see with the scope. 7.5 Vrms is within tolerance without loads.
Now there is something weird happening when the outputs should be independent. I don't really know if it is normal. You can see the outputs on the multimeter between the 2 reads and blacks jacks. I don't know what I should expect but I see 4 V across the jacks. What do you think?
Online Ian.M
Connect a 10K resistor between the two red terminals and re-measure.  I expect the 4.1V will drop by more than an order of magnitude, in which case its probably due to capacitive leakage, and you can calculate the leakage current by ohm's law.  You can confirm its not an insulation defect by a power off resistance check between the two windings.
N.B. unless the transformer is specifically designed and constructed for it, don't expect a high insulation voltage rating between secondaries.  I wouldn't be happy running your transformer with more than 50V between them even though its primary to secondary isolation rating is 4KV RMS!
I checked and indeed, the voltage dropped to 8.8 mV with a 10 k resistance between the two red jacks. There seems to be no insulation defect as shown in the pictures. If I'm not too dumb the leakage current is around 880 nA. Thanks for insights.
