Hello,
I have to connect a motor to a controller. For the controller I have to use a 14 miller connector, so I am gonna buy this one from the manufacturer,
https://www.kellycontrollers.eu/kbl-j2-cableFor the motor there's a rectangular connector with 6 pins, so I will buy this female connector 6 pins,
https://www.kellycontrollers.eu/csatlakozo-kelly-6pin-vizalloBetween the controller and the motor I only connect 4 pins through the rectangular connector, everything else I connect to a PCB/Perfboard and one wire from the miller connector to a circuit breaker.
So the diagram is like this,
|Controller (14 miller)->6 wires->male rectangular connector->|female rectangular connector->4 wires->motor
| |female rectangular connector->2 wires->PCB/Perfboard
|Controller (14 miller)->9 wires->PCB/Perfboard
|Controller (14 miller)->1 wire->Circuit Breaker
As I don't have much experience with cables/connectors, what connectors should I use to connect the wires to the PCB/Perfboard and to the Circuit Breaker. Also, I don't understand how I will join the rectangular connector to the cable with the 14 miller connector.
Meanwhile I will make a drawing to try to clarify my diagram.
Best regards
EDIT: I don't know how to delete the first attachment. They are the same diagram but I made an error on the first one.
