Author Topic: NGD8205N replacement? What to look for comparing IGBTs?  (Read 1746 times)
Offline AmmoJammoTopic starter
« on: March 29, 2017, 05:32:55 am »
I have somehow ended up with an aftermarket car ECU that requires repairs.
Both ignition coil drivers have gone bad, and by bad, I mean they are burnt holes in the board while desoldering themselves.
As a result, there really aren't any pads to fit a replacement SMD device, so I'm looking to go TO220, and mount them to the case.
But, I'm rather lost when it comes to finding a suitable part, the datasheet for the current part is here:
http://www.mouser.com/ds/2/308/ngd8205n-d-304413.pdf
Any advise would be fantastic! Thanks.
Offline danadak
Re: NGD8205N replacement? What to look for comparing IGBTs?
« Reply #1 on: March 29, 2017, 10:59:57 am »
An excellent resource is usually the vendor website for tech help, especially
things like substitutions. You need to supply application, environment,
and help usually forthcoming. Schematic quite helpful.
That being said a circuit design for safe area, drive, and thermal considerations
is not like picking toothpicks out of a box for gum jam relief.
I would focus on gate C, Max rated breakdown voltages, operating current
and saturation voltage, speed.
Regards, Dana.
« Last Edit: March 29, 2017, 11:03:29 am by danadak »
Offline Zero999
  • 0999
« Reply #2 on: March 29, 2017, 11:17:03 am »
How do you know it's only the IGBTs which have gone bad? If they've failed that catastrophically, it's likely they've taken down other components with them.
« Reply #3 on: March 29, 2017, 06:49:57 pm »
I don't have a schematic, and its pretty difficult to follow traces on the board, which I suspect the manufacturer intentionally did.
I don't know that its just the IGBT's, but I don't have an easy way to feed it the required signals to see if everything else is functional.
I know it powers up, and will still communicate with a PC via rs232, so that's a start at least.
« Reply #4 on: March 29, 2017, 06:59:22 pm »
I contacted the manufacturer of the ecu, and they said I could use these:
http://www.mouser.com/ds/2/389/stmicroelectronics_cd00000023-329627.pdf
They did also end their statement with a question mark and its obsolete, so I'm not so sure...
I was considering using these:
http://docs-asia.electrocomponents.com/webdocs/13c0/0900766b813c0822.pdf
