If it is garden lighting use a conduit, otherwise you will be forever replacing cables that have been "gardened" with a spade, fork or whatever going through them, or just nicking them.
I did a lot using just ordinary house wire, the one you pull in a conduit, as twisted pairs in conduit, as I had a few larger 250VA transformers to power them, and with this wire in conduit, and a join box ( 3 way, and filled inside with ordinary lithium grease to keep the water out) to connect the wiring to the individual lamp units. I got tired of the weekly replace mains wiring, and went low voltage so earth faults did not worry me, and 12v 50W dichroic lamps in there, later replaced with 20W ones as they lasted longer, did not run so hot and I could double the number of lamps as well, plus they did not cook the die cast housing seals as much, so they had less water in them. Must have been around 60 of them, plus a dozen 125W mercury floods as either general light or just as accent lighting, along with around a dozen PL bulkheads under plants as feature lights. I do not miss that part of that house, I think I bought a lamp supplier a good number of good quarters, just in lamps and replacement electronic ( and regular potted toroid) transformers and fixture parts, plus a lot of cable and socket outlets and plugs for those running on mains.
Then changing lights in the koi pond, swimming down 2m to get them out, and changing while swimming there. Wonder if Shabby kept up with that, must look one night.
