I need some suggestion/advice; I have an old phone using USB 3 (the smooth round plug that goes in either way) cable to charge and plug into a computer. Unfortunately it's one of those model where the battery isn't replacable and well, the battery is about as dead as a door nail (hard power down after just a few minutes of use after full charge). I need to copy the data including the on-device-only encrypted content to a new phone, and to do that I just need to connect the two phones together using the same cable. If it wasn't for the phone dying after a few minutes after plugging it in this way, that would be easy.
I can keep the phone running by plugging it into power - but that means I cannot connect it to the new one. So my question is, can I create a Y-Cable where I can provide power _and_ plug in the data side too connecting the two phones? It looks like when there's a data connection, power isn't provided between the two devices - will providing power be a problem? Not sure how to find the answer to questions like this - so I'm seeking expert advice in regards to my options here.
Thanks.
