Author Topic: Audio AMP Power vs THD+N ratio  (Read 3175 times)
Offline glatochaTopic starter
« on: July 10, 2013, 11:43:57 pm »
I am designing audio class D amp with TI TPA3125 2x10W amp.
I have found the screen as attached showing THD+N vs supply voltage and output power.
I would prefer to have lower THD+N and this 1 or 1.5W less power is ok for me. But how can I choose at which THD+N it will work?
What determines which curve is actually working.
I have the feeling that I misunderstand the whole concept of this. Can somebody help me out?
Regards
Offline David_AVD
Re: Audio AMP Power vs THD+N ratio
« Reply #1 on: July 11, 2013, 12:30:31 am »
Do you have a specific operating voltage in mind?  If so, find that on the bottom of the graph.  Follow it up to where it intersects the blue line (1% THD).  Then see what max power output that corresponds to on the vertical axis of the chart.
Basically, they are telling you the maximum power output vs voltage with 1% and 10% options.
Offline w2aew
    • My YouTube Channel
« Reply #2 on: July 11, 2013, 02:01:53 am »
THD+N is a function of supply voltage and output power. For example, for a supply of 20V, the THD+N will be 1% or less if the output power is kept below 6W. If the signal is turned up to the point where the power exceeds 7W, then the THD+N will approach 10%.   The curves are intended to show you how these three parameters are related.
FAE for Tektronix
« Reply #3 on: July 11, 2013, 09:12:07 am »
So, basically if the Amplifier has a constant gain it will depend on my input amplitude?
I think I am beginning to understand :)
Offline David_AVD
« Reply #4 on: July 11, 2013, 10:01:11 am »
yes
« Reply #5 on: July 11, 2013, 10:28:43 am »
Thank you all :) :-+
