The 1000V Cat III / 600V Cat iV is a bit of a giveaway, but it's not the first Chinese meter to lie about that. It might still make a reasonable bench meter if you avoid mains outlets (on other than NCV).
The residual counts on the accuracy specs of most functions is on the high side but the resolution is attractive, backlit LCD, bargraph, min/max, all current ranges on their own jack etc.
Unfortunately the only way you're going to find out useful things like continuity test response speed is to find a decent review. I'm probably not up to date of comparative pricing but you may want to compare with better known meters,eg. Uni-T (rather than Brymen or Fluke in that price range!), certainly not the last word in quality but extensively reviewed, teardowns etc. Find a likely looking meter and then do a forum search on model number is probably a good starting point.
Edit: The LED socket identification is quite nice (for those who need it).
