Hello all,
Thank you for having me in your forum
I'm currently trying to replace an EPRPOM (AT27C1024). The chip is off the board and I'm working to get a read from it using a PLCC44 to DIP40 adaptor on my TL866CS (Minipro) . However I'm getting inconsistent reads of the chip.
I've tried moving the adaptor about in the DIP socket to see if it's a connection issue and also applied pressure to the top of the chip during read to check it's making sufficient contact but alas the problem still occurs.
Any advice for getting a consistent result?
