Author Topic: Atmega, USB 3.0, USB 2.0, I2C - Noise?  (Read 566 times)
Offline TantalumTopic starter
« on: March 15, 2019, 04:08:21 pm »
Hello
I'm trying to design a PCB which will host a M.2 LTE Modem and antenna just behind.
I need to avoid EMI as much as possible, but I don't have any scope to make measurements :'(.
So I'm trying to follow the best practices.
The board has the following IC and buses:
- Atmega @8MHz with external oscillator
- INA260 current/voltage sensors, I2C 100kbps
- Temp/humidity SI7013 sensor, I2C 100kbps
- IMU, I2C 100kbps
- LTC4367 overvoltage protection IC with charge-pump (400kHz???) to drive the Mosfet
- USB 3 + USB 2 Mux (2.5GHz and 48MHz)
- SIM Card MUX (1-4MHz)
- 1-Wire bus
So, my questions?
- Would it be a good idea to use a tin shield can over that stuff? Or would the tin can harm the performances of the LTE antenna located just behind (800-2600MHz)???
- Is it useful to add a ferrite bead on the Vcc line of the ICs, to avoid escaping of high frequency noise?
Thank you
« Last Edit: March 15, 2019, 04:11:42 pm by Tantalum »
Offline WildMOSFET
Re: Atmega, USB 3.0, USB 2.0, I2C - Noise?
« Reply #1 on: March 15, 2019, 08:39:55 pm »
I think a minimum of shielding is necessary, leaving the area near the antenna free.
Ferrites are good for blocking electromagnetic disturbances, they are commonly used.
Also insert a nearby ceramic or polyester capacitor on the circuit supply line.
