Author Topic: Zener Diode Clipper Circuits For Both DC and AC Transients  (Read 3156 times)
Offline KJ-90Topic starter
« on: December 14, 2016, 05:24:13 pm »
This may sound like a simple question, but I am wondering about zener diode clipper circuits of the back-to-back anodes type. It involves keeping transients out of test equipment powered by AC wall adapters, which output DC voltage. As we know, TVS diodes are a larger, more powerful version of ordinary zener diode clippers. They can be either unidirectional ( DC ) or bidirectional ( AC ). In an AC circuit, the TVS diode will clip both positive and negative AC peak voltages that it is rated to. For example, a 120 VAC TVS diode might have a clamping voltage of 209 volts peak. The unidirectional DC diode will have a clamping voltage that varies with the reverse stand off voltage ( for example, a 5V TVS diode might clamp at 9V ). Note that of course the breakdown voltages are usually somewhat lower.
However, if I want to protect a Fluke 8040A vintage LED DMM that runs at 7.5 Vdc, how would I connect TVS devices to block both positive and negative DC transients, and AC transients? For example, what voltage ratings of zener diodes connected anode to anode
would I use to block out such transients above say 10 Volts DC negative and positive, and AC as well? What voltage rating of a bidirectional TVS diode would I use also? How are the voltage ratings of devices determined for this application?
Offline Gyro
Re: Zener Diode Clipper Circuits For Both DC and AC Transients
« Reply #1 on: December 14, 2016, 07:43:45 pm »
A Unidirectional TVS will automatically block negative voltage transients - it's a zener diode, it automatically conducts when forward biased (negative transients) and avalanch clamps on positive overvoltage. In this respect the bidirectional TVS is the 'difficult' one because it rquires back-to-back dies in the same package so that it can tolerate both positive and negative supply voltages.
A simple unidirectional TVS (or zener) is all you need to block both positive and negative transients on a DC supply.
« Last Edit: December 14, 2016, 07:45:45 pm by Gyro »
Best Regards, Chris
Offline TimFox
« Reply #2 on: December 14, 2016, 08:36:03 pm »
You can also use a four-diode bridge and a single Zener diode.  The clipping voltage will be the Zener voltage plus two diode drops, but you don't have a difference between the positive and negative Zener voltages found with two Zeners.
Offline Gyro
« Reply #3 on: December 14, 2016, 08:54:16 pm »
Reading again, I'm not sure why you want to block the 7.5V DC supply against "10V DC negative" or AC. Surely you want to block everything other than +7.5V DC. A single unidirectional TVS or Zener (and a fuse) will do this.
Best Regards, Chris
Offline macboy
« Reply #4 on: December 15, 2016, 07:25:33 pm »
I agree, a single zener of suitable voltage (say 10V or so) across the supply will, in combination with a fuse or polyfuse, protect against positive overvoltages as well as negative voltages, which may be even more damaging. Why allow -10V to pass before clamping?
Or are we misunderstanding the application?
