I have an analog multimeter and its schematic is shown in the image below. I would like to create a circuit capable of adding the x100k ohmic scale, using the 50µA/0.1v input, which gives direct access to the galvanometer. If I were to use the same logic employed in the x10k ohmic scale (see the schematic), I would need to have a 125v source (b2) with a 2M resistor (R23). I would like to know if you know of any technique to implement this x100k scale without using high voltage? I was unable to access the schematics, which would give me the opportunity to observe how it was designed, without using high voltage.
