hello everyone
firstly id like to thank those of you taking the time to read my post, hopefully with your help ill be able to learn =]
i have an old asus p5g41t-m lx plus motherboard that turns on but no video. after surfing around youtube and google (for literally many days) i see many with similar issues testing mosfets for shots as well as other troubleshooting to try and pin point the area around the motherboard that was damaged. i took off everything non essential and powered it on, felt around with my fingers for hot components and i noticed the audio ic was VERY hot as well as 2 mosfets (nikos P2003BDG)located near the 24pin connector. i have taken out the audio ic but the issue still remains, so now im trying to test mosfets however, im a bit confused because from what i understand so far a to-252 mosfet should only have continuity at the source and after taking out one of the ones that was getting hot it doesnt give any continuity in any pin, ive tried opening and closing the gate by shorting the drain with gate but i get no beeps at all, i feel it must be bad pretty strongly because the same exact mosfet that is next to it does give me continuity at only the source pin. havent found any mosfets on this motherboard that do have continuity on both gate and source. dont really know if im doing something wrong so i figured it was time to ask for help, my apologies if im noobin =D
