I've had the Mastech 3003 for just short of a year now, and put it through some heavy uses, its quite good. THe difference is the max voltage of the model you linked is 15V vs 30V for mine.
Like anything made in China that is so cheap, I took it apart to check for build quality issues, and found none. Also, those models are used by the RCgroup forum for many years, and you can read about how its held up to their abuse.
The output is stable to at minimum 10 mV for all adjustments, meaning you can dial in 1.010 and 10 mV will stay put, but it can be stable down to 1mV, it depends on the voltage, the higher the better. You can adjust it down to less than 1V without a problem. It has current limiting, and CC and CV. The ripple is better than the spec sheet, I think its under 0.1mV at max load, 3A.
On the downside, the cooling fan is loud. The pots are not multiturn but you can adjust it finely, FYI a multiturn pot by bournes is about $30, over half the cost of the whole unit! There is one user on eevblog who had a broken jack on receipt, but he was able to exchange it for a new one ... but it took a lot of email to get it done. You must email Sean directly, as sometimes what is listed as instock is not really instock, and the shipping cost is high, near $20 due to the weight.
You can find many posts about the Mastech in the archives.
I was recently looking for a cheap dc power supply for beginners.
Ranging from 5v(arduino) to 12v with current limitation and some short-cut protection.
Anyway i don't think i need a lot of power for what i do, basically I'm more into General stuff (No need to power Dc Motors).
I came across 2 :
Atten
http://www.attenelectronics.com/products/dc_power/tpr3003t_05t.htm
Or Mastech
http://www.mastechpowersupply.com/dc-power-supply/linear-power-supply/mastech-regulated-variable-dc-power-supply-hy1503d-15v-3a/prod_64.html
I can get the Atten for 150$ locally, but i have yet never heard of this brand before so i wonder if some of you had experiences about them.
There the Mastech which seems very low priced, didn't read if it had protection though.
