I'm planning to make an audio switch to compare source devices (phone/mp3/etc.) and was hoping I could get some help on the electric aspects of the design.
To give as much info as possible, I've already created a small AB switch in the past using an old JDC C5 amp chassis. I used really small 3.5 connectors and a tiny 3PDT switch. Grounded the jacks to the chassis. Worked great for a while, but ultimately the components are failing.
So... I wanted to make a version 2 with a few functional improvements, but I'm a little weak on the electrical comprehension. My goal is the following:
- more robust switches and jacks
- LED indicator(s)
- transparent audio quality
- passive audio design
- randomization funtion to make somewhat "double blind"
My idea so far is to use a 1590B alumimum chassis for the encolsure. I have a 3d printer, but I've read using a plastic enclosure can allow interference to get into the audio signal? The metal chassis prevents this more by acting like a faraday cage? It's also heavier which may make switching a bit easier.
In any case (pun intended), I was thinking of using a rotary switch like a 2P6T switch. That way I have separate pins for the LEDs and I could essentially spin the knob in a way to sort of randomize the position so I don't know what it is until after I make a guess at which time I could verify the LED status.
I would panel mount the switch and a few decent 3.5 jacks to the case. All simple enough, but here are the aspects i don't fully understand.
- What specifications does the switch need to be? If the audio signal is a low level phone/mp3, etc. meant for earphones/headphones, I assume I need to at least meet some minimum electrical specifications (amps/volts) but how do i determine the ideal specs and is it possible to go too far above the specs and cause an issue? For instance, would i use a 30V/1A switch? If so, and 10A is overkill would it sill work or cause undesired effects?
- What guage of wire is ideal? I assume for that signal level and short distances something like 22awg is fine, but is 20awg better? Any or no benefit? I understand wires have impedance/resistance and conductivity might differ, but i'm assuming those factors are infinitesimally small and irrelevant to this use case in terms of affecting the audio signal?
- Do I ground the switch and all 3.5 jacks to the chassis? Or is there a better method like grounding together and then one to the chassis? I assume that doesn't make any real difference? Do I leave any components (i.e. the switch) ungrounded for any reason?
- Is it possible to find a switch that makes very little to no noise when switching inputs? I've ready about relays and other things, but I'm not too familiar with those. I could also understand using something like arduino to program a randomized "switch", but I don't understand how it would control the physical signal path and not make any noise when doing so? I'm open to any suggestions. I would prefer it isn't insanely expensive or require a lot of battery/power, and I also don't want it to "require" power for the audio (aka, it still works if the LED power dies). The LEDs could run off a 9V battery or something, but not be needed for the audio portion.
- How do I wire the 9V battery/resistors for the LEDs without it interfering with the audio ground/signal quality?
For reference, here is my original AB switch:
https://imgur.com/a/ab-switch-Q02JMCvI just repurposed the shell of the c5 amp (i had extra "shells") and drilled extra holes and wired the components with basic wire. Very basic.
it works perfectly, but if I'm honest, I didn't "fully" understand how to spec the switch... I just found components that fit the case. So I think I just used the switch model that JDS used in their altoids amp.
Anyhow, that's all great, but the desire for something more silent, durable, and perhaps randomized has me confused, and I'd like to make I'm using components and specs to keep things as audibly transparent as possible.
