Author Topic: Audio Amplifier  (Read 3216 times)
Offline staticshockTopic starter
Audio Amplifier
« on: May 10, 2019, 01:16:39 am »
It's been awhile and I may have forgotten some information, but any information provided should sort of point me in the right direction. I need some help on designing an audio amplifier for voice. I'm going to have a 7Vrms input that needs to output one 10Vrms and three 3Vrms. I'm assuming I'll need to amplify the 7V to 10V and perhaps a voltage divider to get the 3V. I've attached a diagram of what the circuit should look like roughly. I'm a bit confused or just may be thinking too hard on how to achieve my objective.
Offline soldar
Re: Audio Amplifier
« Reply #1 on: May 10, 2019, 09:23:18 am »
When dealing with voice you are better off specifying peak to peak because RMS is not a fixed value like it is for a sine wave signal.
Offline Zero999
  • 0999
Re: Audio Amplifier
« Reply #2 on: May 10, 2019, 12:26:52 pm »
You haven't provided enough information: what are the input and output impedances?
Does it need to be Hi-Fi or just telephone quality?
Re: Audio Amplifier
« Reply #3 on: May 13, 2019, 12:22:07 pm »
The input and output impedance aren't specified. There is really no restrictions to the design. I believe the voice audio is over a radio system so I guess telephone quality.
Offline Zero999
  • 0999
Re: Audio Amplifier
« Reply #4 on: May 13, 2019, 06:42:44 pm »
A potential divider can be used to reduce the voltage. If the output impedance is too high, simply connect a unity gain op-amp circuit to the output.
The calculator, linked below, can be used to calculate the resistor values. Use the E24 resistor sequence if you just want cheap, commonly available resistor values.
http://www.ti.com/download/kbase/volt/volt_div3.htm
A non-inverting op-amp configuration can be used to amplify 7V to 10V.
https://www.google.com/search?client=firefox-b-d&q=on-inverting+op-amp
The calculator linked to previously can be also used to calculate the resistor values for the non-inverting op-amp, but where it says "output" enter the input voltage and where it says "input" enter the output voltage. This is because a non-inverting amplifier is just an op-amp connected to a potential divider, so it works in reverse. This is the magic of negative feedback: the op-amp does what it can to keep its inputs at the same voltage.
« Last Edit: May 13, 2019, 06:44:44 pm by Zero999 »
Re: Audio Amplifier
« Reply #5 on: May 22, 2019, 05:36:27 pm »
I've converted all Vrms to Vpp and Vamp, but it seems to affect the simulation calculations in PSpice. They are slightly lower than the actual values. Another thing I wanted to add to the circuit is adding potentiometer in the feedback of the op amps to have the ability to amplify the voltage slightly. One potentiometer seems to work, but one is causing an op amp output to clip. Any help? I can screenshot the schematic and output graph if needed.
Offline strawberry
  • Country: lv
Re: Audio Amplifier
« Reply #6 on: May 22, 2019, 06:03:03 pm »
OP go into cliping when it reaches maximum specified output voltage amplitude ( some OP are rail to rail ..input/output)
In simulation could be some bug or value/setting error...
Offline radiolistener
Re: Audio Amplifier
« Reply #7 on: May 22, 2019, 07:45:15 pm »
« Last Edit: May 22, 2019, 07:49:31 pm by radiolistener »
The following users thanked this post: AlanS
Offline AlanS
Re: Audio Amplifier
« Reply #8 on: May 22, 2019, 10:32:53 pm »
RadioListener - You just made my day. I'll stop laughing sometime around lunch. Good stuff. :-DD
Offline Zero999
  • 0999
Re: Audio Amplifier
« Reply #9 on: May 23, 2019, 08:31:24 am »
That doesn't make any sense without schematics, simulation results etc.
Re: Audio Amplifier
« Reply #10 on: May 24, 2019, 03:34:57 pm »
Well I've figured out the potentiometer. But now I need to add some noise filtering. I've always had trouble understanding where to place capacitors in the circuit. Attached is a drawing of the schematic.
Offline Zero999
  • 0999
Re: Audio Amplifier
« Reply #11 on: May 24, 2019, 04:22:09 pm »
It looks sensible, although normally potentiometers aren't used in the feedback loop. The usual way is to use more gain than necessary and attenuate the input with the potentiometers, although it will work.
The only capacitors you really need are on the power supply rails. You can AC couple the signals around the potentiometers, so there's no DC flowing through them, which can cause noise, when they're adjusted.
Re: Audio Amplifier
« Reply #12 on: June 05, 2019, 05:54:23 pm »
From my thinking, I set the pots in the feedback because the requirement for the amplifier should output 7V to 11V for the first op-amp and 2.5V to 3.5V for the second op-amp. This was the only thing I could thing of to meet that requirement. Other things that I've been thinking of including or modifying in my circuit is a voltage regulator and an automatic gain control. The voltage source available is 28V and I'll need to step it down to 16-16.5V. I don't think I've been exposed to using voltage regulators except voltage dividers..... so not too sure what I can do. As for the AGC, again not a lot of knowledge either than what its purpose is. Could it be something that I can add into my circuit? For my simulations, it's all been done with PSpice, but I'm not sure if PSpice can simulate noise.
Offline Audioguru
Re: Audio Amplifier
« Reply #13 on: June 05, 2019, 06:47:01 pm »
Why are you amplifying 7V to 10V or 11V? The difference is only a little louder.
Why are you reducing 7V to 3V? The difference is only a little less loud.
I wonder why Radiolistener posted a 70 years old vacuum tubes amplifier?
Re: Audio Amplifier
« Reply #14 on: June 05, 2019, 07:24:34 pm »
The input 7Vrms signal is apparently too low and it's just been written down that it needs to be amplified to 10Vrms for intercom. The 3Vrms will be going into three different channels for intercoms as well.
I think he may have posted to troll me  :-//
Offline Audioguru
Re: Audio Amplifier
« Reply #15 on: June 05, 2019, 08:34:06 pm »
Whoever told you that 7V is not loud enough and it must be amplified to 10V never tried it and does not understand that our hearing 's sensitivity to loudness is logarithmic. 10 times the power sounds only twice as loud.
Maybe the 7V must be reduced to 3V to avoid clipping in the other intercom amplifiers.
Re: Audio Amplifier
« Reply #16 on: June 10, 2019, 01:29:21 pm »
Well I've just been updated with more information and the input is NOT 7Vrms, but it is 0.7Vrms. I don't think it poses any major issues other than changing resistors???? Also is it better to keep the op amps as non-inverting or change to inverting? I'm also having trouble finding an Automatic Gain Control (AGC) chip that will fit with the existing circuit.
Offline HB9EVI
Re: Audio Amplifier
« Reply #17 on: June 10, 2019, 03:21:18 pm »
Well 7Vrms or 0,7Vrms is some difference; for the OPA is just a matter of the dividers, you're right there.
If inverting or non-inverting might depend on the output impedance of your 0.7Vrms; if it's low-Z it's possible to use an inverting opamp, if it's hi-Z you rather go for the non-inverting since it has high impedance input.
Why do you need an AGC?
Re: Audio Amplifier
« Reply #18 on: June 10, 2019, 05:48:36 pm »
My senior acquaintance suggested it. I'm assuming for the same reasons as in Radio applications: want the output to be constant no matter what the input is. (It's not a requirement, but could it be beneficial to my circuit?)
Offline HB9EVI
Re: Audio Amplifier
« Reply #19 on: June 10, 2019, 05:58:09 pm »
hmm, well an AGC is on the receiver side of a transmission, its existance is owed to the fact of signal fading and other influences on the signal in the transmission path.
on the sender side signal conditioning is normally done with a compressor; I wouldn't bother to build that discrete but rather go for a ready product like the SSM2166
Offline Audioguru
Re: Audio Amplifier
« Reply #20 on: June 10, 2019, 07:45:53 pm »
Now that you reduced the input to 0.7V does the output still need to be amplified to 10V?
10V RMS is a very high signal level, maybe it must drive a loudspeaker? Then you need a power audio amplifier, not an opamp.
Where does the noise come from, is the intercom used in a noisy factory? If you filter away high noise frequencies then you also filter away the important high frequency consonants sounds of speech.
Background noise jumps up and down during speech when AGC is used.
Re: Audio Amplifier
« Reply #21 on: June 10, 2019, 07:52:31 pm »
I will find out in the next few days about all of that.
Offline Doctorandus_P
Re: Audio Amplifier
« Reply #22 on: June 10, 2019, 10:32:31 pm »
Have a look at simple single chip audio amplifiers:
TDA2030 or TDA2050.
Nowaday's small class D amplifier boards from China / Ebay are also common.
Re: Audio Amplifier
« Reply #23 on: June 12, 2019, 07:48:37 pm »
Well I have been updated with new information, but my design is pretty much going back to a blank slate. I'm now required to replicate existing circuits, but modify them for a variable gain. The existing circuits used AD840 op amps, but they are now obsolete. From TI I've found OPA846 as the cross reference, but if anyone knows of another substitute for that op amp, please let me know. Also most circuitry use transformer coupling, which I've never been introduced to. Is there a certain type of transformer I need to use?
Offline HB9EVI
Re: Audio Amplifier
« Reply #24 on: June 12, 2019, 08:05:07 pm »
maybe you should fill the blanks for us.
normally in audio circuits you don't work with variable gain, but you adjust the signal level before the amp by a simple pot.
also I don't understand why to take such rf opamp for an intercom; why aren't some normal TL082/084 not enough? why transformer coupling?
if you want some serious advise you should tell more what we are talking about
