Thanks Terry this helps a lot.
I did not use the RC power filter, just filter caps.
And actually I have no idea why I had in my head that the DAC could not take any loads - sorry about that - I just tested it and it handles a 18k Ohm load without problems (I literally get 0% voltage reduction).
To answer your question about the -22dB it is for 2 purposes:
* I get a bit of white noise when the +8dB gain is on. It is not loud but you can hear it when no audio is playing. When I switch the gain to -22dB it is very quiet.
* Also I control the volume digitally by reducing the bittage, and I do not want to go lower than 12bits - so my idea was:
** 16 bits = +8dB
** 15 bits = +2dB
** etc. until 12 bits = -16dB
** then I can go back to 16bits and reduce the analog volume by -22dB
** then -28dB with 15bits
** etc. until -46dB with 12 bits
Do you think adding the active low-pass filter like you presented will reduce the white noise? Or is only to improve the audio?
And thanks, I'll check charge injection, I did not know about that
@Jan: Thank you - actually I did notice some ringing around 2.65MHz (of about 100mV) on the output. It only appears with one pair of headphones (and I tested many) which has a long "spiraly" cable, which I guess has a lot of capacitance. Am I right that adding these would help reduce the ringing?
If say I want to cut above 100kHz, how to I get the value?
Also - why only on U3.2 and U3.4 (and not U3.3 which is also output to the left channel)?
