Author Topic: EMF X2 caps ratings question  (Read 435 times)
Offline BobsonTopic starter
  • Country: ru
« on: June 06, 2024, 07:16:14 am »
Got a box of Okaya 250V EMF caps. There are designations "1414 125V, 1283 250V". I understand that these are UL conformance ratings, but could not decide if I can use them as X2 caps with 230V line. Why UL 1414 125V rating?
tia
Offline Vovk_Z
  • Country: ua
Re: EMF X2 caps ratings question
« Reply #1 on: June 07, 2024, 03:32:09 am »
Can you show a photo?
  • Country: ru
« Reply #2 on: June 07, 2024, 04:59:14 pm »
Here they are.
Offline Gyro
« Reply #3 on: June 07, 2024, 06:21:11 pm »
The UL etc. markings will cover things like flammability.  Unless the package specifically includes the characters X/ X1 / X2 on it, it is not suitable for across-the-line mains use. X markings have specific meaning in terms of breakdown voltage, and most importantly, self-healing capability.
Edit: Sorry, looking again at the photos, they do have an X ratings!
« Last Edit: June 07, 2024, 06:27:22 pm by Gyro »
Best Regards, Chris
  • Country: ru
« Reply #4 on: June 09, 2024, 04:53:02 am »
Found Panasonic ECQUV series datasheet with the same designations, https://industrial.panasonic.com/cdbs/www-data/pdf/RDI0000/RDI0000C291.pdf.
It also states UL 1283 250V and UL 1414 125V. Strangely enough, UL 1414 does not deal with X2 type, only X1 and Y1/Y2, and states 125V only for double-insulated equipment without grounded chassis.
My intended purpose is to use these caps for grounded equipment (replace RIFA caps in old HP PSUs) , so I presume they would be OK for 230V mains (unless being corrected by knowledgeable person).
« Last Edit: June 09, 2024, 04:54:57 am by Bobson »
