I have a temperature sensor of a sauna that I want to read via MCP3008 and a raspberry pi. I am already using 4 LMT86 sensors on the MCP3008 with no issues. The sauna sensor consists of two unknown type ntc thermistors in parallel as shown in the attached photo.
Temperature/resistance observations are as follows:
Temp C Bead Glass
7 71K 18K
25 53K 10K
50 31K 6K
I have tried to understand how to use Steinhart Hart to figure this out but I'm a little bit stuck on the equation itself and how the two thermistors are being read by the existing microcontroller.
Edit: added schematic to show the temp sensor connections to the MC.
Any help or direction would be appreciated.
Jerry
