Author Topic: PCF8575  (Read 983 times)
Offline Sai ShobyTopic starter
  • Country: sg
PCF8575
« on: October 13, 2020, 01:57:49 am »
Hi all,
I am trying to control switches in PCF8575 through I2C, when I press the switch which is connected in port0 in PCF8575, I want to glow the led which i connect in port1 of pcf8575. i attached schematics. Please help me to solve this
Offline greenpossum
Re: PCF8575
« Reply #1 on: October 13, 2020, 02:21:52 am »
It's just an I2C to GPIO adaptor, not a FPGA or CPLD, you need a MCU to implement the action.
Offline HB9EVI
Re: PCF8575
« Reply #2 on: October 13, 2020, 12:47:17 pm »
would be useful to know, how you control the I2C bus?
I have some C code for the PCF8575 on AVR, but no idea if it is for any help for you
  • Country: sg
Re: PCF8575
« Reply #3 on: October 14, 2020, 03:55:21 am »
Thank You for your reply. I am using pic 18f25k80 to connect scl and sda
Offline HB9EVI
Re: PCF8575
« Reply #4 on: October 14, 2020, 11:22:52 am »
ok, as you maybe know the PCF8575 is widely used in I2C-backpacks for HD44780-compatible LCD displays, so I normally use the following code to control them, here a write sample
void lcd_write(uint8_t data, uint8_t type) {
    uint8_t temp=0x0;
    uint8_t i=2;
    do {                                                              // verify is LCD is ready to receive commands)
        i2c_start();
        i2c_write(LCD_ADDR + I2C_WRITE);    // address PCF8575 in write mode
        i2c_write(0x8a);                                       // write command
        i2c_write(0x8e);                                       // latch command (toggling Enable pin)
        i2c_start();                                               // I2C restart
        i2c_write(LCD_ADDR + I2C_READ);      // address PCF8575 in read mode
        temp=i2c_read_nack();                            // read PCF8575 pin status with non-ACK
        i2c_write(0x8e);                                        // latch command (set Enable pin)
        i2c_write(0x8a);                                        // reset Enable pin
    while(temp & 0x80);                                     // do loop all over till LCD is ready
    while(i) {
        if(i==2) {
            temp=data & 0xf0;
        else {
            temp=data & 0xf;
            temp*=0x10;
        if(type==1) {
            temp+=1;
        i2c_write(temp+0x8);
        i2c_write(temp+0xc);
        i--;
    i2c_stop();
the I2C commands are AVR compatible, so I thing they are not fully portable to PICs, but the manual should give you a clue about it
  • Country: sg
Re: PCF8575
« Reply #5 on: October 15, 2020, 01:02:13 am »
Yes. got it. Thank you
